Posts : 97 Join date : 2014-01-13 Location : Oshawa On.
Subject: LO5 AIR system vacuum solenoid for 92 RMW Mon Sep 01, 2014 12:16 pm
Hi All, I need the AIR system vacuum solenoid (at least that's what I think it is) that's mounted beside the passenger side valve cover. I was taking the vacuum line off to hook up a vacuum gauge but the vacuum line nipple broke off so I had to glue the vacuum line in place but I doubt it's very well sealed.
Subject: Re: LO5 AIR system vacuum solenoid for 92 RMW Tue Sep 02, 2014 9:04 pm
I may be able to get one for you. I will check on my next visit to the yard. You could just plug the line, or cap it at the T. Unless you need it for emissions, the whole AIR system is just added weight.
Subject: Re: LO5 AIR system vacuum solenoid for 92 RMW Wed Sep 03, 2014 12:10 am
if your ever in kingston ontario i deleted my air system and you can have the parts, my vacuum solenoid has all the fittings intact but the tabs that keep the two halfs together broke off. zip ties fixed it perfectly for me.
j2rossit
Subject: Re: LO5 AIR system vacuum solenoid for 92 RMW Wed Sep 03, 2014 9:36 pm
Thanks guys, Benn, I'll be driving through Kingston on Friday, I'll PM you for the times to see if they jive with your schedule. Fred, If I can't meet up with Benn or for some reason the parts wont work for me, I'll let you know.
j2rossit
Subject: Re: LO5 AIR system vacuum solenoid for 92 RMW Wed Sep 10, 2014 5:46 pm
Thanks Ben, I installed the solenoid today and it seems to have fixed my vacuum leak. There is a little cover that mounts overtop of the solenoid to hold it in place. It's a real bugger to take on and off some I'm guessing that's why you had zip ties on yours.
Subject: Re: LO5 AIR system vacuum solenoid for 92 RMW Wed Sep 10, 2014 6:17 pm
No problem man! Happy to hear it went to good use. I still have some other parts left over. I'd rather see them put to use then sit around or be thrown out. There free also...
Complete L05 air intake, full tbi exuahst minus manifolds and y pipe and some ac stuff
