 Power Steering Pump
5 posters
s1l1sc
Power Steering Pump Empty
PostSubject: Power Steering Pump   Power Steering Pump Icon_minitimeFri Jan 02, 2015 2:13 pm
I am loosing Power Steering fluid when the wagon is parked - before I start just replacing parts, is there a common failure point?
Topping off every 2-3 days before driving to work is getting a bit old.
Figure I will take care of my intermittend "bendix not engaging" problem while I am under there as well...
71novaguy
PostSubject: Re: Power Steering Pump   Power Steering Pump Icon_minitimeFri Jan 02, 2015 8:13 pm
Mine didn't leak until I replaced it. That was due to the variable steering effort solenoid leaking
scoffman
scoffman
PostSubject: Re: Power Steering Pump   Power Steering Pump Icon_minitimeWed Jan 07, 2015 12:36 pm
hoses start leaking pretty easily
s1l1sc
PostSubject: Re: Power Steering Pump   Power Steering Pump Icon_minitimeWed Jan 07, 2015 2:35 pm
Still haven't made it under there - van needed some work first. Need at least one vehicle thats not under construction... lol
Will try this weekend and see what the issue is. Thanks guys, gives me a few things to poke at.
VT Wagon
VT Wagon
PostSubject: and...   Power Steering Pump Icon_minitimeThu Feb 19, 2015 5:54 pm
Did you figure this out?
PostSubject: Re: Power Steering Pump   Power Steering Pump Icon_minitimeThu Feb 19, 2015 8:34 pm
It will be the high pressure hose...
PostSubject: Re: Power Steering Pump   Power Steering Pump Icon_minitimeThu Feb 19, 2015 8:51 pm
This. Unless you damaged the pump in a collision.... which I know all about, too.
Power Steering Pump
» Power Steering Pump
» Need Power Steering Pump
» Power Steering Lines
