Steve Smith
Posts : 392 Join date : 2010-08-04 Age : 69 Location : Trevose, PA ( north of Northeast Philly)
| Subject: differences between left and right rear brake assemblies Tue May 26, 2015 3:29 am | |
| Boy do I feel like a rookie I installed everything pertaining to the left rear drum brake, and all went well but the right side isn't set up the same in the adjuster area. I need a clear picture showing how the right side should look when fully assembled with the adjuster area clearly visible. The part that makes contact with the star wheel had a "R" for right side on it and seems to be placed differently than the left side. Never liked messing with drum brakes, to damn many parts to have to be placed in the correct location and order Wish it was 4 wheel disc! Any directional help is appreciated. Steve | |
| Subject: Re: differences between left and right rear brake assemblies Tue May 26, 2015 8:59 am | |
| Make sure the adjuster is set the same on both sides.... Star OPENS when spun UP.
Also, there is no "right/left" think of it as "front/rear" | |
| Subject: Re: differences between left and right rear brake assemblies Tue May 26, 2015 9:12 am | |
| The two sides should be mirror images. | |
| Subject: Re: differences between left and right rear brake assemblies Tue May 26, 2015 9:18 pm | |
| here you go steve this is the left u can see a L stanped on the bar that stops the self adjuster in pic right side same u can see a r stamped on it. just to let u know the backing plates themselves are the same left and right | |
| Subject: Re: differences between left and right rear brake assemblies | |
