Posts : 23 Join date : 2018-05-10 Location : Murray Ky
Subject: fuel tank question Sun Jun 02, 2019 5:56 pm
Are the fuel tanks the same for TPI and TBI cars? Thanks
Subject: Re: fuel tank question Sun Jun 02, 2019 6:23 pm
THey are interchangeable, however, the sending unit and fuel pump are different (TBI runs higher pressure).
That said, I believe (I never cut one open) the 94-96 tanks have better baffling. Why you ask? Well, I've owned 14 wagons since 2007 and about a 50/50 split on the motors. The TBIs will fuel starve under 'spirited' driving (aka slamming it sideways through a corner) when under 1/4 tank. It's most annoying to be enjoying said corner only to have the motor cut out and having to shift to N and turn the key while sliding around a corner. Have not had that issue once in an LT1 powered car. Now maybe the 2x fuel pressure makes up the difference, I dunno, but that's my experience.
so..... any wagon tank 91-96 will work, just make sure to change the sending unit and/or fuel pump.
MildBill
Subject: Re: fuel tank question Sun Jun 02, 2019 7:15 pm
Thanks Sprocket. I bought a 94 parts car today, no Eng or Trans. I figured the pump and sending unit would be different. didn't know about the tank. $300 delivered for a parts car.
Subject: Re: fuel tank question Mon Jun 03, 2019 9:18 am
nice
Posts : 7185 Join date : 2009-11-13 Age : 75 Location : Largo, FL 33774
Subject: Re: fuel tank question Fri Jun 21, 2019 11:12 pm
I was wondering the same thing, because I was looking at putting over the axle dual pipes on my 92 OCC. I looked at the clearance for the pipe on the driver's side, and the TBI tank appears to have almost no clearance for the pipe. I was wondering if the 94-96 tank has more clearance in the left front corner for a pipe.
Subject: Re: fuel tank question Sat Jun 22, 2019 1:02 pm
the tanks are outwardly the same dimensions. I can take a pic of my dual exhaust on the 95 if you want.
Subject: Re: fuel tank question Sat Jun 22, 2019 2:47 pm
I believe you, but it is really tight for a left side over the axle pipe.
AzDon
I've never owned an LT1, but assumed they ran more fuel pressure...… The prescribed pressure for my TBI is 10-13 PSI..... What pressure do the LT1s run?
yes just noticed my mistake and it's too old to let me edit it now LT1 runs 40-44 which is higher than the TBI.
jwasner2k
Posts : 15 Join date : 2021-04-02 Location : Las Vegas
Subject: Re: fuel tank question Thu Feb 10, 2022 11:34 am
Hi, does anyone know what the hose size is from the fuel filler neck to the tank? Thanks
Subject: Re: fuel tank question Thu Feb 10, 2022 12:33 pm
It is tapered from one end to the other. There are no hoses available to replace it. There is a company that makes hose and an adapter to fit the filler side from a single size hose. https://www.fillernecksupply.com/
I would have to measure the hose to give you a size. The larger hose size is on the tank neck, and you use the adapter that fits the filler neck.
The upper/vent hose is 18 mm, but 19 mm or 3/4 in will work if you clamp it tightly. Use only fuel line.
I believe the hose is 2 inch, and the adapter sizes it down to 1 3/4 inch.
