 Bypass fuel enable?
rcktpwrd
CanaveralSB
6 posters
CanaveralSB
Bypass fuel enable? Empty
PostSubject: Bypass fuel enable?   Bypass fuel enable? Icon_minitimeMon Sep 28, 2020 6:09 pm
So, the friend I sold my '94 RMW wagon to (when I bought my 96) has a problem.  The car was stolen with the key in it (don't ask...) and she had lost her spare (I mean, Jeez, Jennifer).  Our local whiz mechanic managed to get a new key cut via the VIN but the security system is proving harder to defeat.  He has managed to get a work-around for the starter, but the fuel enable will not switch on. He says that there used to be guys that could reflash the chip that sits in the bowels of the dash but he can no longer find anyone who does it.  So, we have a car sitting and not starting.  Options at this point are to find a junker with keys and bring matched keys and chip over to this car - and then deal with all the locks...urghhh. Or?  Well I'm hoping that one of you chaps will supply the "or." One way or another we need to bypass the fuel enable or get that chip reset.
Any suggestions?
Thanks.
rcktpwrd
rcktpwrd
PostSubject: Re: Bypass fuel enable?   Bypass fuel enable? Icon_minitimeMon Sep 28, 2020 7:17 pm
If it's the chip in the key, a Chevy dealer can make the proper key using the VIN.
You can also program out the need for the VATS using tuning software.
Fix Until Broke
PostSubject: Re: Bypass fuel enable?   Bypass fuel enable? Icon_minitimeMon Sep 28, 2020 7:38 pm
Or just put a resistor in across the two wires at the base of the steering column that is the same value as the pellet in the key. No more security, but that's been demonstrated to not be an issue here Smile
PostSubject: Re: Bypass fuel enable?   Bypass fuel enable? Icon_minitimeMon Sep 28, 2020 9:57 pm
If they don't have a factory key they don't know what resistance to use.
If they got a key cut using the VIN why didn't they get the correct chip key?
The fuel enable portion has to be programmed out of the PCM. Then you unplug the module and ground the connector with a paperclip.
Fix Until Broke
PostSubject: Re: Bypass fuel enable?   Bypass fuel enable? Icon_minitimeMon Sep 28, 2020 10:28 pm
True - maybe a 10 turn potentiometer and turn it until it works or a set of 15 resistors?  FSM says to wait 4 minutes between attempts so you'd have at most an hour in figuring it out.
[Bypass fuel enable? Passkey-resistance-code-table
PostSubject: Re: Bypass fuel enable?   Bypass fuel enable? Icon_minitimeTue Sep 29, 2020 6:03 pm
So much easier and quicker to just go to a local dealer and have the proper key made.
Fix Until Broke
PostSubject: Re: Bypass fuel enable?   Bypass fuel enable? Icon_minitimeTue Sep 29, 2020 7:08 pm
Agreed - At least there is more than one option.
PostSubject: Re: Bypass fuel enable?   Bypass fuel enable? Icon_minitimeTue Sep 29, 2020 9:07 pm
You could also have the computer flashed to remove the VATS.
CanaveralSB
PostSubject: Re: Bypass fuel enable?   Bypass fuel enable? Icon_minitimeWed Sep 30, 2020 1:30 pm
Thanks for all the suggestions guys! I should have mentioned that the new key came with the correct chip, but the decoder is not reading it - thus the hope to get it re-flashed. Fred, do you know of anyone that currently does this? (In that you mentioned it). Thanks again.
rjathon
rjathon
PostSubject: Re: Bypass fuel enable?   Bypass fuel enable? Icon_minitimeWed Sep 30, 2020 3:33 pm
www.pcmforless still does it.
Russ
PostSubject: Re: Bypass fuel enable?   Bypass fuel enable? Icon_minitimeWed Sep 30, 2020 5:43 pm
Simple. Just need a laptop an ALDL cable and a copy of TunerPro and EEHACK.
Bypass fuel enable?
» Throttle Body Bypass??
» 1991 RMW ignition module woes
» Amsoil bypass oil filtration system
» 9C1 silicone hose heater core bypass
