 Steering Wheel Replacement
higgo9673
Steering Wheel Replacement Empty
PostSubject: Steering Wheel Replacement   Steering Wheel Replacement Icon_minitimeWed Nov 16, 2022 6:57 pm
Good evening.
New here so hopefully I am doing this correctly
I have a 1995 Buick Roadmaster Wagon and the steering wheel is in bad shape. I found one off a 95 Park Avenue that is in really good shape but it has the steering wheel controls on it.
Will I be able to use this one or do I need to get one that does not have the controls on it.
Thanks for any advise
PostSubject: Re: Steering Wheel Replacement   Steering Wheel Replacement Icon_minitimeWed Nov 16, 2022 7:34 pm
As long as they have the same splines it will fit just fine. I installed a Monte Carlo wheel with controls on a previous wagon. To use them you must grab the clock spring from the Park Avenue and install it in your wagon. It also requires an adapter and a radio that is compatible with the controls which I don't think your factory one is. Don't know for sure because the radio is the first thing to get replaced when I bring a car home.
higgo9673
PostSubject: Re: Steering Wheel Replacement   Steering Wheel Replacement Icon_minitimeWed Nov 16, 2022 8:00 pm
Thanks for the info. Should be the same splines so going to take a chance.
» Bye-Bye air bag steering wheel! Hello Leather Olds wheel!
» need steering wheel
» Steering wheel?
» Steering Wheel
» New (to me) steering wheel...
