| 96 Roadmaster Rear lower control arms | |
jeffracer
Posts : 98 Join date : 2010-11-18 Age : 74 Location : Tampa, Floriduh
| Subject: 96 Roadmaster Rear lower control arms Thu Nov 18, 2010 11:28 pm | |
| My new wagon is in great shape except for a fubar by the previous owner when he put jack stands under the rear control arms and lowered the jack. Twisted comes to mind.............
I am in need of a pair of stock lower control arms and they are NLA from Govt Motors. Anyone have a source? | |
| Subject: Re: 96 Roadmaster Rear lower control arms Thu Nov 18, 2010 11:47 pm | |
| Aftermarket or junkyard. Junkyard will be cheaper, but remember, the "newest" ones will be 15 years old......
it's not the arms, it's the bushings. | |
jeffracer
| Subject: Re: 96 Roadmaster Rear lower control arms Fri Nov 19, 2010 7:02 am | |
| - Krzdimond wrote:
- Aftermarket or junkyard. Junkyard will be cheaper, but remember, the "newest" ones will be 15 years old......
it's not the arms, it's the bushings. Are new bushings are readily available? | |
Nick Danger
| Subject: Re: 96 Roadmaster Rear lower control arms Fri Nov 19, 2010 11:29 am | |
| Does it have to be stock? I was very happy with the C3Fab aftermarket lower control arms. The aftermarket arms are a lot sturdier than the factory arms. | |
| Subject: Re: 96 Roadmaster Rear lower control arms Fri Nov 19, 2010 8:50 pm | |
| Subject: Re: 96 Roadmaster Rear lower control arms Fri Nov 19, 2010 10:03 pm | |
| Just remember that the stockers are floppy for a reason. They offer better road isolation and absorb some of the binding that inevitably occurs in the suspensions on these cars. | |
| Subject: Re: 96 Roadmaster Rear lower control arms Fri Nov 19, 2010 10:06 pm | |
| - sherlock9c1 wrote:
- Just remember that the stockers are floppy for a reason. They offer better road isolation and absorb some of the binding that inevitably occurs in the suspensions on these cars.
I thought that was just the upper ones. You can box the lowers and use a Crown Vic anti-roll bar with no harm to the car. | |
jeffracer
| Subject: Re: 96 Roadmaster Rear lower control arms Mon Nov 22, 2010 9:19 pm | |
| Will lower arms from a 92 estate wagon fit a 96 estate wagon? If so I found a you pull it yard that has a 92.
If Yes, what size wrenches do I need to pull the lower arms. My wagon is 30 miles from me at the moment so I can't go look and the 92 wagon is 30 miles in the opposite direction. | |
| Subject: Re: 96 Roadmaster Rear lower control arms Tue Nov 23, 2010 12:37 am | |
I thought that was just the upper ones. You can box the lowers and use a Crown Vic anti-roll bar with no harm to the car. The upper ones are mainly in tension, so they can be built more spindly. The lower ones are in compression and they tend to deform under heavy acceleration and let the axle move around, causing unpredictable handling. If you install the Crown vic bar, you completely bypass the control arms and don't need to do a bloomin' thing to them. | |
jeffracer
| Subject: Re: 96 Roadmaster Rear lower control arms Tue Nov 23, 2010 3:24 pm | |
| Went to the U-Pull-It yard and got the pair of lower arms off a 92 Roadmaster wagon for $22. I was going to shoot a couple of photos of the car but there wasn't much of value left on it, the car was pretty well cannibalized. | |
| Subject: Re: 96 Roadmaster Rear lower control arms | |
