 Heat issues
Heat issues Empty
PostSubject: Heat issues   Heat issues Icon_minitimeFri Jan 14, 2011 9:39 pm
Here we go for the short version as I am on my phone.
Car started to overheat- got to almost half on the gauge and I had no heat in the car.
replaced the thermostat with a failsafe 180* stat. no change.
Flushed the core and broke the restrictor in the process. All good with the core. Hose splice works fine.
Next thought was the pump......until I found that when in vent mode I get LOTS of heat. Turn on the defrost - or anything with the AC - and I get cold air again.
fan on low I get heat with AC, the faster the fan, the colder it gets.
can I just remove the AC relay and disable the compressor? Is there a plug on the pump?
I NEED THE DEFROST as it is now getting to low 20s here.
TIA
Robert
Heat issues Empty
PostSubject: Re: Heat issues   Heat issues Icon_minitimeFri Jan 14, 2011 9:56 pm
You don't happen to have a spare control head laying around do you?
It's odd that the car itself got hot.
The a/c compressor does have a plug if worse comes to worse.
Heat issues
» Starter issues? Heat soaked? no experience any help would be appreciated.
» No heat on 95 rmw
» No Heat! Ha!
» The cause of no heat!!!!!!!!
» No heat in my 95 RMW!
