| 4-note horn conversion? | |
+8jimbeau Sprocket Cadet57 brokecello 94Woody BigBlackBeaSSt DBeaSSt 81X11 12 posters |
| Subject: 4-note horn conversion? Thu Jan 20, 2011 2:44 am | |
| My 79 Buick and my old 95 Park Ave Ultra both have/had 4-note "tugboat" horns from the factory. My Roadmaster wagon is only a 2-note, same as the old '86 Caprice. I just learned the Roadmaster sedans use the 4-note horns. Anyone installed those on a wagon? I've not even looked to see where mine are mounted....just curious.
If I'm going to have a car this big I need a horn blast to match! ; ) | |
DBeaSSt Admin
| Subject: Re: 4-note horn conversion? Thu Jan 20, 2011 6:28 am | |
| Roady Sedan and Fleetwood had the four note horns. Two mount where yours are, left fender, the other two mount on the other side, same location. Grab the horns from a boneyard car and to make life easier, grab the horn harness too. Someone on here has done it. I hope to this spring, I have the parts. | |
| Subject: Re: 4-note horn conversion? Thu Jan 20, 2011 8:18 am | |
| Yes I have the "Love Boat" mod.......... Pulled horns from a Caddy I think or maybe a Roady sedan......
Love it!! Really gets respect when you light them up!!!! | |
| Subject: Re: 4-note horn conversion? Thu Jan 20, 2011 8:20 am | |
| I did it last spring when I swapped my fenders, thanks to Chris for alerting me to the difference.
The right side fenders already have the mounting points in them. I just grabbed the four horns and harness from a Buick (RM) Sedan. Bolt on the horns and wire in the harness and viola. Sounds like a boat and lead to me calling my wagon "The Barge" lol.
The "harness" I removed was really just a single wire with a split connection on one end for the two horns. I just spliced into my current horn wire and it works great.
Wagon is currently under a cover in the driveway or else I would post some pics. | |
| Subject: Re: 4-note horn conversion? Thu Jan 20, 2011 9:21 am | |
| Do you have to change all four horns, or can I just add the wire and the two on the other fender?
Sorry for being such a tightwad. ; ) | |
| Subject: Re: 4-note horn conversion? Thu Jan 20, 2011 9:44 am | |
| I added the two and used the "harness" to jumper them in. No problems.............. | |
| Be sure to get the bolt that holds them in. You will need it........ | |
| Subject: Re: 4-note horn conversion? Thu Jan 20, 2011 9:46 am | |
| 10-4. I need an excuse to go salvage yard.... | |
| Subject: Re: 4-note horn conversion? Thu Jan 20, 2011 1:03 pm | |
| I have these horns too. Waiting until Spring Break to do it. It'll be legit. |
brokecello Moderator
| Subject: Re: 4-note horn conversion? Thu Jan 20, 2011 7:42 pm | |
| Subject: Re: 4-note horn conversion? Thu Jan 20, 2011 8:16 pm | |
| Had to use the horn in the hearse once on the highway. That cleared some traffic | |
| Subject: Re: 4-note horn conversion? Mon Jul 23, 2012 8:16 am | |
| *Bump*
A friend traded me a set of these horns so I can do the mod. However, it didn't include the bolts to install them. Do I *need* them or will a bolt from Ace work? | |
| Subject: Re: 4-note horn conversion? Mon Jul 23, 2012 8:25 am | |
| Don't see why a regular bolt wouldn't work. |
| Subject: Re: 4-note horn conversion? Mon Jul 23, 2012 9:38 am | |
| Subject: Re: 4-note horn conversion? Mon Jul 23, 2012 9:42 am | |
| Subject: Re: 4-note horn conversion? Thu Jul 26, 2012 6:12 pm | |
| You can only use the bolt that was designed to those horns. Since you don't have one, I suggest you box them up and ship them directly to me. I am an alchemest and will create the magical bolt and install them in my car. | |
| Subject: Re: 4-note horn conversion? Thu Jul 26, 2012 6:16 pm | |
| - Sprocket wrote:
- You can only use the bolt that was designed to those horns. Since you don't have one, I suggest you box them up and ship them directly to me. I am an alchemest and will create the magical bolt and install them in my car.
I'll put them in the same box as your door pulls. Which are going out tomorrow for real this time with a bonus gift | |
| Subject: Re: 4-note horn conversion? Thu Jul 26, 2012 7:32 pm | |
| So, this four note deal plays the first line of "Dixie"? | |
| Subject: Re: 4-note horn conversion? Fri Jul 27, 2012 9:23 am | |
| More like Move Over Beetoven. | |
Nick Danger
| Subject: Re: 4-note horn conversion? Sun Jul 29, 2012 8:48 pm | |
| I was able to attach Gary's headlight relay set to the fender underneath the rear horn. It all fits, but it's really tight. | |
rh96ss
Posts : 315 Join date : 2009-02-26 Location : Port Orange FL or in the air
| Subject: Re: 4-note horn conversion? Mon Jul 30, 2012 12:18 am | |
| Is that a 2 or 4 relay harness? Looks like a 2 relay or at least different from my 4 relay harness. | |
Nick Danger
| Subject: Re: 4-note horn conversion? Mon Jul 30, 2012 12:24 am | |
| I have the two relay harness. It's also an older harness that I bought used. Gary may have redesigned the relay package. | |
VT Wagon
Posts : 100 Join date : 2014-11-16 Location : Central Vermont
| Subject: Re: 4-note horn conversion? Tue Nov 25, 2014 5:34 pm | |
| - Nick Danger wrote:
- I have the two relay harness. It's also an older harness that I bought used. Gary may have redesigned the relay package.
2 relay's = four horns. | |
| Subject: Re: 4-note horn conversion? | |
