roadmastercouple
Posts : 459 Join date : 2012-02-13 Age : 36 Location : Augusta GA
| Subject: Tranny problem Fri Aug 03, 2012 12:04 pm | |
| Just blew a transmission line need to know which transmission is in my car can anybody help | |
| Subject: Re: Tranny problem Fri Aug 03, 2012 12:51 pm | |
| Yours is a 700R4, also known as the 4L60 (no E) | |
| Subject: Re: Tranny problem Fri Aug 03, 2012 1:10 pm | |
| Mike
You may be able to make a temporary / permanent repair with high pressure hose made for tranny's. It is available at auto parts stores. Cut out the bad piece, then install a piece of high pressure hose. Double clamp on either end.
roadmastercouple
| Subject: Re: Tranny problem Fri Aug 03, 2012 1:32 pm | |
| Thanks guys I replaced the lines with high pressure rubber ones when I put new radiator in but ome slipped out of the bracket and burned o hole on the exaust. | |
scoffman
| Subject: Re: Tranny problem Fri Aug 03, 2012 2:32 pm | |
| Can you get extra length on them hoses and zip tie them further away from the exhaust pipe? I can't remember how close to, or where they are routed but it might be worth doing if that's the only problem. X2 on it being a 700R4 or 4L60 transmission. If you want to try and find a cheap used one I would suggest www.car-part.com | |
roadmastercouple
| Subject: Re: Tranny problem Fri Aug 03, 2012 7:17 pm | |
| to be honest it scared the s*** out of me I looked in my rear view mirror couldn't see out my back window on the trail of smoke. confused me at first because I did not have a lack of power. I thought I might have blown the engine it first. and I called advanced auto they're trying to tell me that it takes 11 court just doesn't sound right to me. my hands manual says 10 pints so still a little confused. thanks for the tip scoffman will pick up some zip ties when I go. | |
| Subject: Re: Tranny problem Fri Aug 03, 2012 7:35 pm | |
| 11 quarts is if everything including the converter (Fresh Rebuild) is dry. When doing a trans service it should be about 5 quarts | |
| Subject: Re: Tranny problem | |
