 9C1 silicone hose heater core bypass
Wagoninabox
6 posters
9C1 silicone hose heater core bypass Empty
PostSubject: 9C1 silicone hose heater core bypass   9C1 silicone hose heater core bypass Icon_minitimeFri Sep 26, 2014 9:58 pm
A co-worker of mine generously gave me the silicone hoses off a 9C1 police Caprice he parted out. On the lines to/from the heater core, there's a couple of tees and a bypass hose between them. Anyone know why this would have been done? I have another set of heater hoses off another 9C1 equipped Caprice and they aren't hacked in this way.
Wagoninabox
Wagoninabox
PostSubject: Re: 9C1 silicone hose heater core bypass   9C1 silicone hose heater core bypass Icon_minitimeFri Sep 26, 2014 11:28 pm
Someone will chime in with the answer, but I wanted to point out you should look into the correct clamps for these hoses. They are silicone and used a different type of clamp that did not risk cutting into the material when tightening.
PostSubject: Re: 9C1 silicone hose heater core bypass   9C1 silicone hose heater core bypass Icon_minitimeSat Sep 27, 2014 12:32 am
Yep, I am aware of that. I have the proper stainless steel clamps for silicone hoses on-hand. The fact that it has those clamps on it certainly leads me to believe it to be non-factory.
Viceroy454
Viceroy454
PostSubject: Re: 9C1 silicone hose heater core bypass   9C1 silicone hose heater core bypass Icon_minitimeMon Oct 06, 2014 10:20 pm
Might have had a coolant filter at one time. I have tees in my heater hoses for exactly that.
benn
benn
PostSubject: Re: 9C1 silicone hose heater core bypass   9C1 silicone hose heater core bypass Icon_minitimeMon Oct 06, 2014 11:42 pm
maybe a home brew technique for flushing the system????
PostSubject: Re: 9C1 silicone hose heater core bypass   9C1 silicone hose heater core bypass Icon_minitimeTue Oct 07, 2014 1:19 am
I'm going to guess that this was done to reduce the amount of heat getting into the cabin. Police cars do tend to sit idling for hours at a time.
PostSubject: Re: 9C1 silicone hose heater core bypass   9C1 silicone hose heater core bypass Icon_minitimeTue Oct 07, 2014 8:34 am
They may have come from a 91 that had a vacuum operated bypass valve to stop water flow to the heater core when the AC is on.
You are also missing the restrictor for the non bypass systems. The "rigged" set of hoses may be compensating for that omission.
PostSubject: Re: 9C1 silicone hose heater core bypass   9C1 silicone hose heater core bypass Icon_minitimeTue Oct 07, 2014 11:03 am
The restrictor is there, just not on that side of the hose set. Thankfully I ended up with two sets of 9C1 silicone heater hoses, because one of the restrictors had gone out-of-round and wouldn't seal properly! Since those were already cut I had some ability to do some physical "cut and paste".
Oh that reminds me, I used a brass connector to splice the hose together, and I'm curious if that's a known bad idea. Galvanic corrosion or other issues, perhaps?
PostSubject: Re: 9C1 silicone hose heater core bypass   9C1 silicone hose heater core bypass Icon_minitimeTue Oct 07, 2014 3:43 pm
There is a sacrificial anode in the system to keep the galvanic activity in check. Plastic is preferred, because it is for the most part inert.
PostSubject: Re: 9C1 silicone hose heater core bypass   9C1 silicone hose heater core bypass Icon_minitimeWed Oct 08, 2014 12:55 am
Fred, if there is (was) a sacrificial anode in that system somewhere, I'm sure it was sacrificed. Very Happy
The inside of that block is coated in rust!
PostSubject: Re: 9C1 silicone hose heater core bypass   9C1 silicone hose heater core bypass Icon_minitimeWed Oct 08, 2014 8:54 am
So, think it through. If the sacrificial anode is gone, how does adding another dissimilar metal added to the mix affect the system.
PostSubject: Re: 9C1 silicone hose heater core bypass   9C1 silicone hose heater core bypass Icon_minitimeWed Oct 08, 2014 10:53 am
I'd say it depends, Fred. There's already dissimilar metals in the system, so really only 3 things can happen here. 1: the corrosion inhibitors will prevent anything bad from happening (until they wear out), 2: the addition of brass will accelerate corrosion, or 3: the brass itself becomes sacrificial and slowly dissolves over time until the thing starts leaking Very Happy
I'm waiting on some more ABA hose clamps, so next opportunity I get after that I'll install a (plastic) flush tee where that brass coupler is now, just in case. I'm also thinking about adding a screen to catch the little bits of engine block rust that are floating around there.
Viceroy454
Viceroy454
PostSubject: Re: 9C1 silicone hose heater core bypass   9C1 silicone hose heater core bypass Icon_minitimeWed Oct 08, 2014 10:01 pm
Run a coolant that contains molybdate. That will protect any brass in your system. Dissimilar metals cause so many problems in cooling systems, because most coolants are equipped only to protect a narrow range of metals. Different inhibitors protect different metals. Certain inhibitors that protect one metal may also set about destroying another metal.
That's why I run Rotella Ultra. It loves all metals and solders.It's like a big, fat, kind, happy foster mother for your cooling system.
PostSubject: Re: 9C1 silicone hose heater core bypass   9C1 silicone hose heater core bypass Icon_minitimeWed Oct 08, 2014 10:48 pm
Good tip! thanks Smile
PostSubject: Re: 9C1 silicone hose heater core bypass   9C1 silicone hose heater core bypass Icon_minitimeWed Oct 08, 2014 11:58 pm
The most active metal (ie: able to liberate hydrogen from the electrolyte) will be the sacrificial anode. At the really active end of the scale are metals like Magnesium, Aluminium, Zinc and Iron.
Towards the middle are metals like Nickel, Tin and Lead, which require a fairly acidic electrolyte.
At the non-active end of the scale are Copper, Silver, Platinum, and Gold.
Brasses are alloys of at least two pure metals, and the activity level varies a bit by the specific alloy. However, most brasses are generally even less active than most stainless steels. So your brass won't be the sacrificial metal.
The flip side is that the greater the difference between two metals, the faster the more active one will corrode. So the presence of brass will accelerate the corrosion of the aluminium, since it is probably less active than the iron.
PostSubject: Re: 9C1 silicone hose heater core bypass   9C1 silicone hose heater core bypass Icon_minitimeMon Oct 20, 2014 12:48 am
I wanted to follow up on this with some garage science based on what buickwagon posted and what I remember from chemistry class.
I did replace the brass connector with a plastic one (Prestone flush tee, which may come in handy) once I got hold of some nice marine grade hose clamps.
I put the brass connector and a piece of the aluminum tubing from my old heater core and put them into a small cup, I added some filtered water and attached them to a DVM. I read 590mV, with the brass being the positive terminal, meaning that the aluminum is the anode in this chemical battery. That seemed a lot higher than I expected. Then I replaced the water with some 50/50 mix of Prestone and distilled water. Even more surprisingly, I get 632mV out of that battery, again with an aluminum anode. I didn't have a piece of cast iron on hand to test that, but based on this, it seems like there would be a galvanic reaction in antrifreeze between a brass fitting and the aluminum in the cooling system.
So, it's probably best to stay away from any metal aside from aluminum and iron which are already in the system, or go with gold or platinum if you can afford it. Smile
If there's really a sacrificial anode in the system, does anyone know where it would be? I did some digging and can't seem to find any mention of it. There aren't too many places you could stick it.
PostSubject: Re: 9C1 silicone hose heater core bypass   9C1 silicone hose heater core bypass Icon_minitimeMon Oct 20, 2014 11:13 am
Wow. I sure didn't see that one coming. Who'd have thought that Prestone is a more efficient electrolyte than water? No wonder things corrode in there. Neat experiment.
» 9C1 Green Silicone Heater Hose conversion on 93 LTZ
» Drip Pan for Heater Core and A/C removed - next steps - type of silicone?
» sloshing in heater core (?)
» Heater core!
» heater core?
