| TBI stock air intake switch to a custom air cleaner... | |
+3Sprocket Fred Kiehl 86Knives 7 posters |
86Knives
Posts : 7 Join date : 2014-10-25
| Subject: TBI stock air intake switch to a custom air cleaner... Sun Oct 26, 2014 8:00 pm | |
| I want to remove all the stock plastic on the top of my motor and put a chrome air cleaner onto the TBI. Will there be any problems just switching it out? Or do I need to make other modifications? | |
| Subject: Re: TBI stock air intake switch to a custom air cleaner... Sun Oct 26, 2014 8:11 pm | |
| You'll need a bent stud from a 4.9L Cadillac at the junkyard (or order a new one from Jegs or Summit), and you'll have to tap a hole in the bottom for the intake air temp sensor. Then, put a breather filter on your PS valve cover (or tap another hole for that piece of hose.
Otherwise, nah. |
86Knives
| Subject: Re: TBI stock air intake switch to a custom air cleaner... Sun Oct 26, 2014 8:52 pm | |
| Awesome. I think I'll save up my pennies and modify. Thanks. | |
| Subject: Re: TBI stock air intake switch to a custom air cleaner... Mon Oct 27, 2014 9:04 am | |
| You will also need the bolts from the caddy TBI to get rid of the long studs that hold the toaster. Consider looking into the cold air Caddy hat/Home Depot/Lowes intake. There are a couple of varieties of it, and if the vapor canister is in the way of the air filter, you can use a mount from a 94-96 to move it under the wheelhouse. | |
| Subject: Re: TBI stock air intake switch to a custom air cleaner... Mon Oct 27, 2014 8:00 pm | |
| 86, I have a Caddy intake and said bent mount, you'll need a tube and cone filter give me a buzz if you wanna go that route. Stock photo, not my actual [You must be registered and logged in to see this link.] | |
| Subject: Re: TBI stock air intake switch to a custom air cleaner... Mon Oct 27, 2014 8:11 pm | |
| Caddy, schmaddy. To use a standard Chrome Air Cleaner, Spectre makes the required stud and the factory Throttle Body bolts are not an issue. [You must be registered and logged in to see this link.] | |
| Subject: Re: TBI stock air intake switch to a custom air cleaner... Tue Oct 28, 2014 1:45 pm | |
86Knives
| Subject: Re: TBI stock air intake switch to a custom air cleaner... Wed Oct 29, 2014 12:01 pm | |
| Now we're talking. Thanks for the info! | |
| Subject: Re: TBI stock air intake switch to a custom air cleaner... Wed Oct 29, 2014 12:11 pm | |
| Pay attention Stubby NoMods!! | |
AzDon
| Subject: Re: TBI stock air intake switch to a custom air cleaner... Sat Dec 13, 2014 1:19 pm | |
| I read somewhere that deletion of the air cleaner surround tube results in a loss of HP and is a potential fire hazard when using a paper filter....The thread I was reading (I wish I could remember where) said our plastic snorkle filters are the second-best for HP.... | |
| Subject: Re: TBI stock air intake switch to a custom air cleaner... | |
