 how to test temp sender
papa
how to test temp sender Empty
PostSubject: how to test temp sender   how to test temp sender Icon_minitimeTue Dec 08, 2015 2:54 pm
As is being discussed in another topic , my 91 caprice wagon over heated big time last summer. The needle on the temp gauge went out of site and has stayed pegged ever since. I have figured out that the temp sensor in the intake, that communicates with the ECM was ruined. I suspect that the same thing happened to the temp switch in the head, that works the gauge. How can I check the switch to see if that's the problem? Cross the two wires in the connector? I have tried unplugging the wires and nothing happens. Question
PostSubject: Re: how to test temp sender   how to test temp sender Icon_minitimeFri Dec 25, 2015 6:41 pm
The sensor changes values with temperature. You can remove it (the water will leak out of the block unless you plug the hole with another one) and measure the output while heating it in a pot of hot water. The specs are in the FSM. I believe the resistance goes up with temperature, but I do not know the number off hand.
PostSubject: Re: how to test temp sender   how to test temp sender Icon_minitimeFri Dec 25, 2015 8:04 pm
sounds like the gauge itself is buggered,..
PostSubject: Re: how to test temp sender   how to test temp sender Icon_minitimeSat Dec 26, 2015 1:59 am
Resistance is inversely proportional to temperature. IE resistance goes up as temperature goes down. You probably don't have to drop it in boiling water for a quick check -- if you know the outside temperature with a cold engine, you can check against the chart in the FSM.
With an engine temperature of 68°F, the sensor resistance should be 3520 ohms (3.52 Kilo ohms).
59°F is 4.45 Kohms
50°F is 5.67 Kohms
-15° is 21.45 Kohms
-40°F is 100.7 Kohms
If the resistance at the sensor seems OK, then check the resistance at the PCM between C25 and B16. It should be the same. Higher means resistance in a wire or connection, lower means something is shorted.
» Faulty Temp Gauge? Coolant temp sensor?
» Fuel pump & sender
» Oil pressure sender location(s)
» Wiring the oil pressure sender for Camaro gauge swap
» Replaced Oil Pressure Sender - Heard Sparking - Won't Start - Scared
