 Motor Mount
Skier
Motor Mount Empty
PostSubject: Motor Mount   Motor Mount Icon_minitimeFri Dec 30, 2016 9:46 pm
I may need to replace my oil pan so may  as well replace the motor mounts.  What brand is the best?  On Rock Auto price runs from $1.59 to $93 for ACDelco.  Are the ACDelco mounts that much better or just outragesley over priced?
'95 RMW
Motor Mount Empty
PostSubject: Re: Motor Mount   Motor Mount Icon_minitimeSat Dec 31, 2016 8:11 am
Whats wrong with your motor mounts,..?
Motor Mount Empty
PostSubject: Re: Motor Mount   Motor Mount Icon_minitimeSat Dec 31, 2016 10:53 am
You are looking at making some tools to reach the bolts for the mounts. I replaced mine with the lower suspension arms off, and it was a PITA. The lower bolts are almost impossible to reach with the lower arms installed. Upper bolt can be reached through a hole in the front of the cross member. I got a set of urethane inserts and reused the clamshells. You have to make sure you get the inserts in right side up. I would never try doing it myself with the lower suspension arms in place. The cost of having a mechanic do it is cheap.
Skier
Motor Mount Empty
PostSubject: Re: Motor Mount   Motor Mount Icon_minitimeSat Dec 31, 2016 4:06 pm
After talking to my youngest brother, I will leave the motor mounts in they are not broke.
Motor Mount Empty
PostSubject: Re: Motor Mount   Motor Mount Icon_minitimeSat Dec 31, 2016 4:20 pm
Good choice.
Motor Mount Empty
Motor Mount
» trans mount
» Ball Mount Rise
» transmission mount shims
» WTB: Front Plate Bracket/Mount
» OCC Front License plate mount.
