yourownself
Posts : 4 Join date : 2017-02-09
| Subject: Woody doors on plain sided wagon? Tue Mar 28, 2017 10:36 pm | |
| Anyone know any reason why I wouldn't be able to use a epoxy door on my wagon? I just have the rub strip on my Pontiac, but I found a fantastic deal on a door from a Buick woody. TIA. | |
| Subject: Re: Woody doors on plain sided wagon? Wed Mar 29, 2017 9:15 am | |
| Not sure what an epoxy door is. If the door is the same, you can remove the wood sticker, and remove/fill any mounting differences. I assume you have a box wagon, because the bubble ones did not come in the Pontiac flavor. | |
yourownself
| Subject: Re: Woody doors on plain sided wagon? Wed Mar 29, 2017 12:21 pm | |
| Damn. I shouldn't post on mobile after drinking. Apparently "woody" autocorrects to epoxy. Who knew? Yes I have a box wagon. An 85. I assume the doors are the same, but I'm not certain. I was more worried about whether the door will have a bunch of mounting posts or holes that would have been used for the woody trim that I'll need to fill. If that's the case, this door may not be as good of a deal as it seems. Thanks for the reply. | |
| Subject: Re: Woody doors on plain sided wagon? Wed Mar 29, 2017 12:30 pm | |
| Usually there are posts and holes for the top outline trim. The rub strip may use the same mounting points.
You type epoxy if you have your left hand one key to the right. | |
| Subject: Re: Woody doors on plain sided wagon? | |
