64vette
Posts : 9 Join date : 2009-09-25 Age : 73 Location : North Carolina
| Subject: heating up while at hwy speed? Mon Aug 02, 2010 3:38 pm | |
| The 95 RMW has started heating up while at constant hwy speed. I can take it out of overdrive and as the engine RPM increases, it will cool down. Could the radiator stop up like the heater core does? I installed a new radiator about 40k ago and a new water pump about 80K ago. Your thoughts please. | |
| Subject: Re: heating up while at hwy speed? Mon Aug 02, 2010 4:44 pm | |
| I would suspect the water pump impeller to be slipping if this is the case. | |
| Subject: Re: heating up while at hwy speed? Mon Aug 02, 2010 8:40 pm | |
| i,d check the thermostat,. if its stuck up it'll heat up at hiway speed ,.water has no soak time in the rad,. Nick | |
64vette
| Subject: Re: heating up while at hwy speed? Tue Aug 03, 2010 5:59 pm | |
| Well, rather than trial and error, I changed the pump, thermostat and flushed the radiator. Problem seems to be solved. I am going on a 40 mile trip tomorrow. I'll keep you posted. Thanks for the replies. | |
| Subject: Re: heating up while at hwy speed? Tue Aug 03, 2010 6:18 pm | |
| - 64vette wrote:
- Well, rather than trial and error, I changed the pump, thermostat and flushed the radiator. Problem seems to be solved. I am going on a 40 mile trip tomorrow. I'll keep you posted. Thanks for the replies.
well that certainly covers all bases,. no more thoughts required,. nick | |
| Subject: Re: heating up while at hwy speed? | |
