| Fuel leak | |
Burdaddy
Posts : 19 Join date : 2019-12-21
| Subject: Fuel leak Sun May 10, 2020 3:11 pm | |
| From what I can tell my sending unit lines are rotted. Wont know how bad the main lines are til I can drop tank. What are my options if the ends of lines are rotted? Never had this problem before n I've lived in Ohio my whole life. | |
| Subject: Re: Fuel leak Sun May 10, 2020 7:17 pm | |
| If bad on the sender side, replace sender. If the connectors or lines are bad on the car side, there are repair ends at any parts shop. Two different sizes (pressure and return) as well as the rubber vapour line. | |
Burdaddy
| Subject: Re: Fuel leak Sun May 10, 2020 7:31 pm | |
| Thanks. I'll try to drop the tank this week if weather holds out. Almost 20° drop n storm after bein mid 60s **** ain't workin with me. From what I can see under car the lines are rusty as hell. The lines on body dont have any metal parts do they? I cant remember. | |
rcktpwrd
Posts : 544 Join date : 2019-03-06 Age : 49 Location : Raleigh, NC
| Subject: Re: Fuel leak Sun May 10, 2020 7:51 pm | |
| The lines are a plastic material, but the connectors are metal. | |
rcktpwrd
| Subject: Re: Fuel leak Sun May 10, 2020 7:53 pm | |
rcktpwrd
| Subject: Re: Fuel leak Sun May 10, 2020 7:57 pm | |
| also a set of disconnect tools is helpful [You must be registered and logged in to see this link.] | |
Burdaddy
| Subject: Re: Fuel leak Sun May 10, 2020 8:02 pm | |
| I did pick up one a few months back to do vette dress so I'm good there. Thanks for the pic. I think my connectors may be rotted from your pic but I'll know for sure when I get at it. Maybe I'll get lucky. | |
Burdaddy
| Subject: Re: Fuel leak Fri May 15, 2020 4:29 pm | |
| Sorry for bad pics. Waitin on a new phone. Seems my fuel line connectors were metal. Key word, "WERE." [You must be registered and logged in to see this link.] | |
rcktpwrd
| Subject: Re: Fuel leak Fri May 15, 2020 5:37 pm | |
| looks like you could use a repair kit on those... [You must be registered and logged in to see this link.] | |
Burdaddy
| Subject: Re: Fuel leak Sat May 16, 2020 9:52 am | |
| Msgd girl at parts store. She looked up some numbers and is gettin me the dorman tool shipped in without the connectors and box. Saved over $100 n I'll just grab the fittings while I'm there. Even gettin her discount too. Just have to wait for the tool to be shipped from dorman. | |
rcktpwrd
| Subject: Re: Fuel leak Sat May 16, 2020 3:58 pm | |
Burdaddy
| Subject: Re: Fuel leak Fri May 22, 2020 6:47 pm | |
| Anyone parting a wagon? I need the fuel lines asap. | |
| Subject: Re: Fuel leak Fri May 22, 2020 9:22 pm | |
| Original lines are no longer available, and I wouldn't waste any time putting old nylon in. I'd cut the line and put a new end on it. You can buy 5/16" and 3/8" fittings and there are tools that can shove them into the existing lines (definitely put them in boiling hot water for a bit beforehand). If you can't do it, have it towed to a shop that can do it.
I'm actually seriously thinking about running all new lines in my wagon just to prevent a fuel leak and fire. | |
Burdaddy
| Subject: Re: Fuel leak Thu May 28, 2020 8:08 pm | |
| Ok I think the Roadbastard is good to go... somewhat. Got new pump n unit installed and found these fuel line unions from dorman. They're push type. First try I had a cut in line above union so still leaked. Cut again and installed a new one and so far so good. Fuel light is on too so I may be low or may have (edit) up my sending unit. I'll put couple gallons in tmrw to verify.
Edit: added fuel and needle didnt move. I hate doin pumps. I dont think I'm gonna mess with it again. | |
Burdaddy
| Subject: Re: Fuel leak Fri May 29, 2020 11:25 am | |
| Ok guess it was emptier than I thought... and I was slightly drunk. Took almost 4 gallons for it to finally move. Get insurance set up n run uptown to top off tank. Love these big cars for roadtrips... just not dirt roads. Incase anyone is curious these are the connectors I used. Was I think $8 for a pair at advance. Sorry for crap quality pic. [You must be registered and logged in to see this link.] | |
rcktpwrd
| Subject: Re: Fuel leak Mon Jun 01, 2020 12:43 pm | |
| good to see you got it fixed! | |
Burdaddy
| Subject: Re: Fuel leak Mon Jun 01, 2020 3:45 pm | |
| Me too. Miss drivin my lt1s. Got to mash the skinny pedal yesterday to pass some dumb broad on her cellphone n a Tahoe. 35-40 in a 50 zone n on brakes at every little turn. Hammer down n gone!! | |
sdowney717
Posts : 111 Join date : 2017-01-01
| Subject: Re: Fuel leak Sun Oct 11, 2020 5:51 pm | |
| Those are the best solution, mark the insertion end with tape so you KNOW they went in all the way home. And grease the tubing. Dont bother with pressing new fittings, likely to be very frustrating experience. Dorman sells a short section of tubing with a new end already pressed in. For these cars, tubing is 3/8 coming from pump, return line is 5/16
I got it all from O'reiley . You can also buy all new tubing on a roll. | |
| Subject: Re: Fuel leak | |
| Fuel leak | |
