| Help! Rear window needed fast! | |
mtennant
Posts : 79 Join date : 2012-09-30 Age : 69 Location : Georgetown, SC
| Subject: Help! Rear window needed fast! Fri Jun 05, 2020 11:55 am | |
| I'm outside of Amarillo, TX where the rear window on my 1991 Oldsmobile Custom Cruiser spontaneous shattered.
I'm on my way to Eureka Springs Arkansas via Oklahoma City. I'm contacting junk yards for availability.
Any advice would be appreciated. I'm planning on driving without it if I have to.
Many thanks,
Marty Tennant | |
| Subject: Re: Help! Rear window needed fast! Fri Jun 05, 2020 12:07 pm | |
| Hopefully there is a forum member on your route that may know of a JY with a wagon. Glass shattering like that is not common, but it does happen.
Good Luck
| Subject: Re: Help! Rear window needed fast! Fri Jun 05, 2020 12:33 pm | |
| In case you haven't checked: car-part.com | |
mtennant
| Subject: Re: Help! Rear window needed fast! Fri Jun 05, 2020 1:33 pm | |
| THANK YOU! Car-part.com was the ticket. I'm on my way to Roosevelt 580-639-2308 to pick up a glass window for $100.
mtennant
| Subject: Re: Help! Rear window needed fast! Fri Jun 05, 2020 4:09 pm | |
| Hard to believe that I was able to get a new rear window so quickly. The name of the place in Roosevelt Oklahoma was Parts World. | |
| Subject: Re: Help! Rear window needed fast! Fri Jun 05, 2020 4:23 pm | |
| Probably wouldn't be a bad idea to crack open a couple of windows to let out the heat.
mtennant
| Subject: Re: Help! Rear window needed fast! Fri Jun 05, 2020 4:30 pm | |
| 97 degrees in OK. NO AC. WINDOWS DOWN! | |
| Subject: Re: Help! Rear window needed fast! Fri Jun 05, 2020 4:47 pm | |
| - mtennant wrote:
- 97 degrees in OK. NO AC. WINDOWS DOWN!
Also when you park it. | |
| Subject: Re: Help! Rear window needed fast! Fri Jun 05, 2020 4:59 pm | |
| Glad to help, enjoy the rest of the trip! | |
| Subject: Re: Help! Rear window needed fast! | |
