 Oil level sender delete- switch setting?
Sleeperwagon
Oil level sender delete- switch setting? Empty
PostSubject: Oil level sender delete- switch setting?   Oil level sender delete- switch setting? Icon_minitimeMon Jun 22, 2020 10:14 pm
I put an aftermarket pan on the LT1 with no provision for the level sensor. I have read that this switch will cause a no-start condition if the oil level is low, so I need to know how to wire it to bypass the switch. Is the switch normally open, or normally closed? Not sure if I need to jumper the contacts at the end of the wire or just tape it up out of the way. I am cross-posting in electrical in case it is more appropriate there, so mods please delete if this is the wrong spot. Thanks!
PostSubject: Re: Oil level sender delete- switch setting?   Oil level sender delete- switch setting? Icon_minitimeMon Jun 22, 2020 11:11 pm
It is only there for convenience. It affects nothing but the light on the dash.
PostSubject: Re: Oil level sender delete- switch setting?   Oil level sender delete- switch setting? Icon_minitimeTue Jun 23, 2020 12:58 pm
It will still start with the light on. I put a new GM sensor in mine and the light was still on so I fired up Tuner Pro and turned it off.
» Low coolant level sensor switch
» TBI factory idle setting
» how to test temp sender
» Fuel pump & sender
» Fuel sender replaced! Woo hoo!
