Airborne455
Posts : 23 Join date : 2020-11-29
| Subject: reluctor gear for 3.23 8.5 rear Thu Dec 03, 2020 10:56 pm | |
| Worth a shot.....looking for a 21 tooth abs reluctor gear for a 3.23 ring and pinion set. gm part number 26018944
Thank you. | |
| Subject: Re: reluctor gear for 3.23 8.5 rear Sun Dec 06, 2020 9:39 pm | |
| These are long discontinued. You may be better off having someone with a CNC machine make one. I believe Clear Image makes 3.42 and 3.73 reluctors and may be willing to make one for you. | |
Airborne455
| Subject: Re: reluctor gear for 3.23 8.5 rear Mon Dec 07, 2020 2:08 am | |
| Thank you for the advise. I will give them a call. | |
| Subject: Re: reluctor gear for 3.23 8.5 rear Mon Dec 07, 2020 6:19 pm | |
| I'd contact Bob Shirley over on the SS forum. | |
Airborne455
| Subject: Re: reluctor gear for 3.23 8.5 rear Mon Dec 07, 2020 6:29 pm | |
| Will do. Thank you! I called clear image and he advised that his CNC folks would have to make a minimum of 100 gears. | |
| Subject: Re: reluctor gear for 3.23 8.5 rear Thu Dec 10, 2020 3:00 pm | |
| They may be discontinued, but if you have the part number, there may be a stray one somewhere in the GM system, in an obscure closed Buick/Oldsmobile dealership. I found some discontinued parts like that a while ago. | |
| Subject: Re: reluctor gear for 3.23 8.5 rear Thu Dec 10, 2020 3:04 pm | |
| It might be easier to put a 3.42 gear in it, and get the available tone ring. | |
Airborne455
| Subject: Re: reluctor gear for 3.23 8.5 rear Thu Dec 10, 2020 3:22 pm | |
| Yes sir at this point it’s looking like that’s what I’m going to have to do. | |
| Subject: Re: reluctor gear for 3.23 8.5 rear | |
