| oil adapter gasket replace gone wrong | |
| Subject: oil adapter gasket replace gone wrong Sat Feb 12, 2011 7:31 pm | |
| So Dusty had been leaking oil from the oil adapter above the filter. I spoke to someone last week who said, "its's not that hard and the parts are $5". The $5 part was correct the other part not so much.....
Anyhoo, I got it all back together just after dark and it leaks worse than before......anyone know the proper torque for the allen screws? I'm hoping if I get an allen socket I can snug them up some more.
| Subject: Re: oil adapter gasket replace gone wrong Sat Feb 12, 2011 8:22 pm | |
| No clue Captain Chaos...... | |
| Subject: Re: oil adapter gasket replace gone wrong Sat Feb 12, 2011 8:25 pm | |
| well Dustan on the other forum told me to go buy the Fel-Pro kit. I'm surprised my parts store didn't give me that one as they are a Fel-Pro retailer.....hmmm
Yeah, I'm not feeling this avatar for long...it's already wearing on me, lol | |
| Subject: Re: oil adapter gasket replace gone wrong Thu Feb 17, 2011 8:20 am | |
| According to the FSM for a 92, the oil filter adapter bolt should be 18 lb. ft., but it does not say anything about the bolts being an allen head. | |
| Subject: Re: oil adapter gasket replace gone wrong Fri Feb 18, 2011 9:29 pm | |
| It's an LT1 and I'll be back under there this weekend as it's a quart down in 5 days. | |
| Subject: Re: oil adapter gasket replace gone wrong Fri Feb 18, 2011 9:44 pm | |
| Kinda figured the SP on the locomotive stood for Sprocket. Just A Guess Jim Gordon |
| Subject: Re: oil adapter gasket replace gone wrong Sat Feb 19, 2011 9:04 pm | |
| Turns out I pinched the O-ring when I put it up...... Luckily It's fairly easy. Took the time to clean it all up even more today. and now NO LEAKS! | |
94X2
| Subject: Re: oil adapter gasket replace gone wrong Mon Feb 28, 2011 6:05 pm | |
| I now believe the jealously theory extends to reading about other wagons. Although I'm sorry you had to go thru this repair I'm glad you did since I knew to watch the o-ring on mine today. So far so good. I also replaced the oil level sensor while I was under there. 2 leaks down and who knows how many to go Jon | |
| Subject: Re: oil adapter gasket replace gone wrong Tue Mar 01, 2011 6:25 pm | |
| What is that car in your avatar and how can I get one??? | |
94X2
| Subject: Re: oil adapter gasket replace gone wrong Tue Mar 01, 2011 7:06 pm | |
| It's a Buick Blackhawk concept car. You can find the picture online but the real thing might be a little tougher. If you figure out a way let me know | |
| Subject: Re: oil adapter gasket replace gone wrong Tue Mar 01, 2011 8:27 pm | |
| well I musta whacked one of the sensors, cuz the SES light is on and the gas mileage is in the toilet right now what a PITA. Yeah I like that concept car.... | |
94X2
| Subject: Re: oil adapter gasket replace gone wrong Wed Mar 02, 2011 5:12 pm | |
| - Sprocket wrote:
- well I musta whacked one of the sensors, cuz the SES light is on and the gas mileage is in the toilet right now
what a PITA. Yeah I like that concept car.... Sounds like one of my repairs. I probably need to buy 2 of every part so I have them on hand for the second time around Have you checked the 02 wires on that side? I had a time getting the cooler lines loose with those in my way. Jon | |
Nick Danger
| Subject: Re: oil adapter gasket replace gone wrong Wed Jun 15, 2011 11:59 am | |
| My oil filter adapter is leaking. I was going to replace that gasket today. But everyone seems to think it's a major PITA.
One guy on a Corvette forum said that it was difficult, and he had his engine on a stand, upside down.
The leak's not all THAT bad. I think I'll put off doing it for when I have more time. Do you have any suggestions for making the job easier? | |
| Subject: Re: oil adapter gasket replace gone wrong | |
