| Spectrum Premium fuel pump | |
| Subject: Spectrum Premium fuel pump Sun Aug 21, 2011 9:03 pm | |
| I was looking for the PDF of Joel's fuel pump recalibration and found that Autozone sells the SP128B1H complete sending unit with pump for $132. Rock Auto has the 127B1H for $8 less (plus shipping). Question is, are these reliable and are they the same units with store specific model numbers?
I have decided that it is better to just buy new than to risk rebuilding a 16 year old pump/sending unit. that and from what I have read on ISSF, the new unit fixes the known problems with the stock unit. | |
| Subject: Re: Spectrum Premium fuel pump Mon Aug 22, 2011 7:45 am | |
| Although I can't comment on that one, I can say when I bought the Walbro 255 unit, The plasric mounting cylinder had to be modified along with the vibration sleeve.,
My concern is , are you doing mods that will eventually require more fuel than a stock flowing pump can provide?
| Subject: Re: Spectrum Premium fuel pump Mon Aug 22, 2011 9:19 am | |
| My fuel gage is no longer reliable and twice this week the car would not start without first "priming the pump". Tank is full and a new(ish) filter installed. Just wanted to recalibrate the sending unit on a spare pump/sending unit when I found the new one locally.
This is a case of "an ounce of prevention is worth a pound of cure".
I am just curious if the sp127 and sp128 are the same unit with OE PSI and flow rate. | |
| Subject: Re: Spectrum Premium fuel pump Mon Aug 22, 2011 3:40 pm | |
| Can't comment on the fuel pump part, but installed their sending unit in the Caddy (had a brand new pump already). Totally cured the fuel gauge inaccuracy problems.
Bill | |
| Subject: Re: Spectrum Premium fuel pump Mon Aug 22, 2011 7:40 pm | |
| Biggest thing I discovered (the hard way) is not so much having the gauge accurate when it is full, It's making sure it's accurate when it's says empty. | |
| Subject: Re: Spectrum Premium fuel pump Mon Aug 22, 2011 7:43 pm | |
| - lakeffect wrote:
- Biggest thing I discovered (the hard way) is not so much having the gauge accurate when it is full, It's making sure it's accurate when it's says empty.
I agree, and now my gauge won't go below 1/4. Put in 19.5 gallons with gauge showing 1/4... so I KNOW it is off. Also getting 179 miles to the tank so I'm running through the "usual suspects" | |
| Subject: Re: Spectrum Premium fuel pump Mon Aug 22, 2011 8:02 pm | |
| I don't see what's wrong with reconditioning an old sending unit, but $132 isn't a lot of money for it. Buy it, ohm it, and if it's good, throw it in. Remember the key - you want to avoid vibration-induced poor connections. | |
| Subject: Re: Spectrum Premium fuel pump Mon Aug 22, 2011 8:26 pm | |
| You can fix it for a coupe of bucks, by putting a variable resistor from radio shack . Here's the part. 10K-Ohm 15-Turn Cermet Potentiometer/Trimmer [You must be registered and logged in to see this link.] It gets sliced into your fuel sender line that is running in a harness next to your hood release, and to ground. There's a body ground inches below the bolts for the hood release. After ward you can dial in your empty tank to zero, but for a margin of error, put in two gallons , THEN dial in Zero. | |
| Subject: Re: Spectrum Premium fuel pump Mon Aug 22, 2011 11:48 pm | |
| - Krzdimond wrote:
I agree, and now my gauge won't go below 1/4. Put in 19.5 gallons with gauge showing 1/4... so I KNOW it is off. Also getting 179 miles to the tank so I'm running through the "usual suspects" Can't agree more. Who cares how long it sits on full. I want to know when its time to feed it before it quits. Exactly the same problem with the Caddy. New sender fixed the problem. Bill | |
| Subject: Re: Spectrum Premium fuel pump | |
