 UMI rear control arms and self leveling
PatDTN
UMI rear control arms and self leveling Empty
PostSubject: UMI rear control arms and self leveling   UMI rear control arms and self leveling Icon_minitimeMon Aug 06, 2012 7:23 am
I bought both upper and lower control arms for my '96 wagon. Beautiful arms to look at indeed. I noted that there are no holes for mounting the ball screw for the self leveling sensor. Anybody else run into that? I want to keep that feature even though I bought Moog cargo coil springs that will be much stouter. I have a set of airlift 1000 bags to use.
http://www.patdonahue.com
PostSubject: Re: UMI rear control arms and self leveling   UMI rear control arms and self leveling Icon_minitimeMon Aug 06, 2012 2:31 pm
Why can't you drill & tap a couple of holes to mount the level sensor?
PatDTN
PostSubject: Re: UMI rear control arms and self leveling   UMI rear control arms and self leveling Icon_minitimeMon Aug 06, 2012 11:01 pm
I didn't need to tap the hole as there was a nut on the end. I used that though I'd have preferred to catch more threads.
PostSubject: Re: UMI rear control arms and self leveling   UMI rear control arms and self leveling Icon_minitimeTue Aug 07, 2012 2:05 am
I wouldn't imagine that there is a whole lot of stress on the switch mount. Maybe some locktite on the threads is all.
PatDTN
PostSubject: Re: UMI rear control arms and self leveling   UMI rear control arms and self leveling Icon_minitimeTue Aug 07, 2012 8:28 am
I did work the switch through its range and it moves quite easily. I think it'll be just fine. On the other upper control arm there was an attachment point for a clip to keep the wire to a sensor in the diff from flopping. I can either cable tie that or maybe do some more drilling. Even as meaty as these arms are they're no match for a sharp bit and a drill press.
» rear control arms ?
» Custom Rear control arms
» Lower rear control arms for 96 RMW
» Rear Control Arms - Lower..
» 96 Roadmaster Rear lower control arms
