| Subject: Dark Blue front passenger door arm rest pad Thu Sep 13, 2012 10:09 am | |
| If anyone had a dark blue front passenger door arm rest pad to sell, please let me know. Mine is warping from the bottom up on my '92 OCC. My other three are perfect. I guess that one door got some sun.
Please let me know if you have one. THANKS!
-Mike | |
| Subject: Re: Dark Blue front passenger door arm rest pad Tue Sep 18, 2012 10:30 am | |
| I usually repair the vinyl on my armrests. I usually use Gorilla Glue. I sprinkle a little water inbetween the vinyl, and the foam, then squeeze a 1/8 inch bead of glue in the crack. To hold them together while the glue sets, I use packing tape and bind it tightly I apply the tape from the top, around the area that is being held in place, and around the back to the top, making a loop around the entire armrest. I use as many parallel strips of tape as needed to cover the entire area that is being repaired. The next day, I take the tape off, and clean any residue with Goof Off or Goo Gone. If the glue protrudes from the repaired area, I just use a razor and cut it off. Any glue will be hidden when the armrest is reinstalled.
I have a repaired one if you are interested.
Last edited by Fred Kiehl on Tue Sep 18, 2012 12:12 pm; edited 1 time in total | |
| Subject: Re: Dark Blue front passenger door arm rest pad Tue Sep 18, 2012 11:40 am | |
| Hey thanks for the info! I'm going to take that off and try to repair it this weekend.
-Mike | |
| Subject: Re: Dark Blue front passenger door arm rest pad | |
