| Help me piece together hitch hardware... | |
udownwitk
Posts : 82 Join date : 2013-12-06 Age : 37 Location : Athens Ga
| Subject: Help me piece together hitch hardware... Thu Apr 03, 2014 7:10 pm | |
| Subject: Re: Help me piece together hitch hardware... Thu Apr 03, 2014 7:24 pm | |
| Everything but the spacer block can be had at your local Orange or Blue store for a LOT less.....
Can't help with the other questions as both my car and memory are no longer here. | |
| Subject: Re: Help me piece together hitch hardware... Thu Apr 03, 2014 7:52 pm | |
| Corey
Robert is correct, but you also can get a big square washer that will work, I did. They (HD) sell a product called Unistrut or Kindorf. It comes in 10 foot lengths. It is used for mounting and securing equipment. Part of that system, they have square washers, about 1 1/2 square x 1/4 or 5/16 thick, with a 3/8 or 1/2 hole. The carriage bolt will lock right in. If for some reason can't them there, go to an electrical supply house. You have to "fish" them in with the bolts. I can't look at my wagon now, but if I remember correctly, you will need four.
| Subject: Re: Help me piece together hitch hardware... Thu Apr 03, 2014 8:52 pm | |
| Only two of them.
For the rear bolts.
At least, that's what I had.
Also, man I am really mad, I can't find that damn bolt for anything! I get the feeling someone tossed it going through the garage because they didn't know what it was. |
udownwitk
| Subject: Re: Help me piece together hitch hardware... Sat Apr 05, 2014 9:27 pm | |
| Niiiiiice.
That's like the best kind of random garage stuff. "Wait, I had WHAT hanging around in there?"
Deadmanonduty
| Subject: Re: Help me piece together hitch hardware... Fri Apr 11, 2014 6:45 pm | |
| I bought a "wagon" hitch from a guy on a forum, and it showed up and was a Sedan hitch! So, a Welder made it fit perfect and its strong as can be!
| Subject: Re: Help me piece together hitch hardware... Fri Apr 11, 2014 7:29 pm | |
| That's a wagon hitch.
Used to be on my wagon :p
| Subject: Re: Help me piece together hitch hardware... Fri Apr 11, 2014 7:45 pm | |
| - Stingroo wrote:
- That's a wagon hitch.
you need to install a hitch in the front,.........to help get home easier,.. | |
udownwitk
| Subject: Re: Help me piece together hitch hardware... | |
