GMjonn
Posts : 166 Join date : 2012-07-25 Age : 63 Location : Dacula Georgia
| Subject: Turn signal stalk removal. Tue May 13, 2014 12:03 pm | |
| I saw a short video some where around here on how to remove the cruise control / turn signal switch/lever. Any one seen it lately? If so let me know. I'm looking for it. | |
| Subject: Re: Turn signal stalk removal. Tue May 13, 2014 12:12 pm | |
| You pull it straight out. Takes a little force. Snaking the wiring for the cruise switch is a bit tougher. | |
GMjonn
| Subject: Re: Turn signal stalk removal. Tue May 13, 2014 1:41 pm | |
| Subject: Re: Turn signal stalk removal. Wed May 14, 2014 9:29 am | |
| Disconnect the wiring before you pull on it.
If it is in the "off" position, you can pull it straight out. If you do not disconnect the wiring first, you will probably rip it loose and break the clip holding the connector to the interior of the steering column. | |
| Subject: Re: Turn signal stalk removal. | |
