MrBuick
Posts : 100 Join date : 2009-02-21 Age : 36 Location : Benton Harbor, MI
| Subject: 94-96 Fuel Pump Ground Thu Apr 22, 2010 3:26 am | |
| Can somebody help me find the fuel pump ground on a wagon? Attempting to help a friend online, but I don't know where they put it on a wagon. The FSM says "LH Rear Lamp Harn, approx 4cm from LH Backup Lamp conn breakout". I didn't know what that meant, so I thought I would compared it to the sedan one. Is says something similar. I know the Sedans have a connector for the tail light/fuel pump harness on the drivers side of the trunk, and then the ground is on the trunk hinge. I have only been in a wagon once, and I didn't really go through it looking for wiring. I can tell you were everything is on a sedan, since I have stripped a few down. I guess I just need to part out a wagon, so I can learn more about them. | |
| Subject: Re: 94-96 Fuel Pump Ground Thu Apr 22, 2010 3:45 am | |
| Cory, if you remove the drivers side storage panel, you will see a grounding point. That's it. | |
MrBuick
| Subject: Re: 94-96 Fuel Pump Ground Thu Apr 22, 2010 5:39 am | |
| That's where I figured it was, but wasn't sure. I was hoping it was not under the carpet. | |
| Subject: Re: 94-96 Fuel Pump Ground | |
