| Found an automotive LED replacement bulb source 4/15/2015 | |
+3Bobloblaw Fred Kiehl 4501 Safari 7 posters |
4501 Safari
Posts : 43 Join date : 2010-05-13 Age : 77 Location : Where the hurricanes don't land in Florida
| Subject: Found an automotive LED replacement bulb source 4/15/2015 Wed Apr 15, 2015 5:36 pm | |
| Posted over on the impalassforum but think most wagon folks would use this information too. I was glad to find it. Electric trains are another way to be abused financially other than our cars. Most are converting the lighting over to led to conserve available power for the more complex electronically operated trains available since our cars were new back in the 90's. Yes the hobbies and the technology seem to have parallel paths in many respects. Looking on the http://ogrforum.ogaugerr.com/ (O Gauge Railroading Forum) this afternoon I noticed a post on led bulbs. The company also has replacements for just about anything we can think of. Not really inexpensive but easily referenced and available. Here's the link: http://www.autolumination.com/ If this is already common knowledge then I wasted a few minutes posting. If you're like me and like to find something useful once in a while, rather than multiple dead ends on the search features, this may help. I found the site illuminating. Richard Snipes 4501 Safari in Jax, FL | |
| Subject: Re: Found an automotive LED replacement bulb source 4/15/2015 Wed Apr 15, 2015 8:19 pm | |
| 194s are available in various colors on ebay for as little as 20 for $7.00. I have not checked other sizes. | |
4501 Safari
| Subject: Re: Found an automotive LED replacement bulb source 4/15/2015 Wed Apr 15, 2015 10:05 pm | |
| So true, Fred, I found the site does provide references for the led bulbs that are available for our cars. I could not find the mirror mounted map reading bulbs, for example, on eBay in led but surprisingly enough they were on Amazon. Hardly 20 for $7.00 though. Maybe someday some one will post a cross reference and source for all the weird little bulbs GM used like the one in the Caprice illuminating the headlamp switch or the one in the Roadmaster door illuminating the inside door handle at night. You see them when they work and when you take apart an assembly in a salvage yard. Find a number though...oh well.
Bobloblaw
| Subject: Re: Found an automotive LED replacement bulb source 4/15/2015 Wed Apr 15, 2015 10:42 pm | |
| Subject: Re: Found an automotive LED replacement bulb source 4/15/2015 Thu Apr 16, 2015 8:35 am | |
| I found an LED replacement for the CHSL at Autozone for about $7 each. I would check ebay before buying one.
I bid on a PAIR if 194 LEDs and did not win. I got a "second chance" to buy them for 25 cents...shipped all the way from China. I just got them yesterday. The only issue is that they are a little tight in the socket. I can not grasp that they can send them from China to the US for $.25 including postage. | |
| Subject: Re: Found an automotive LED replacement bulb source 4/15/2015 Thu Apr 16, 2015 8:57 am | |
| There are exceptions, but in general I have found the LED adaptations lacking. There's nothing really wrong with LEDs, but the light is highly directional whereas an incandescent bulb throws light everywhere -- something that was accounted for in the original design.
It goes for my Lionel trains too. I've tried some LED bulbs in place of incandescent in cars and engines but they just don't do it for me. OTOH, LEDs are great for incorporating tiny lights in scenery!
One exception to the rule: I like LEDs in the spotlight towers. Lionel never did get the reflector design satisfactorily directional -- but the LEDs do!
Just my 2¢. Or, in the case of toy trains: $20. | |
Bobloblaw
| Subject: Re: Found an automotive LED replacement bulb source 4/15/2015 Thu Apr 16, 2015 11:08 am | |
| If you are going to install LED lighting ANYWHERE in your car, make sure you spend the extra money and buy resistors.
Your electrical system constantly throws a current, albeit very low, but still enough to create a glow on the LED's.
Some of the higher end LED's will have a resistor built into the back of the bulbs. Radio Shack has them for cheap if you are looking for them.
If the LED's will be replacing any of your turn signals this mod is a must! They draw such little current. Your car will freak out when activating the turn signal. It thinks that a bulb is burnt out and will rapid flash as a warning.
Couple of things to think about. | |
| Subject: Re: Found an automotive LED replacement bulb source 4/15/2015 Thu Apr 16, 2015 12:02 pm | |
| - Bobloblaw wrote:
- If you are going to install LED lighting ANYWHERE in your car, make sure you spend the extra money and buy resistors.
Couple of things to think about. The reason for resistors in LED lighting is to limit current so the LED will not go into thermal runaway. The electrical system can not have a minimal current if there is an on/off switch in the circuit. The resistor does not have to have a large value...10 ohms max. If you are replacing the turn signal bulbs, change the blinker relay and emergency relay to electronic ones, instead of putting a resistor in the circuit. Putting a resistor in the circuit defeats the purpose of the LED reducing current draw. The lights will not flash with the original relays, because the LEDs do not draw enough current to heat the bimetal strip that breaks the circuit. | |
annapolis
Posts : 34 Join date : 2013-06-10 Location : Panama City Florida
| Subject: head lamp switch illumantion on Caprice Thu Apr 16, 2015 3:00 pm | |
| - 4501 Safari wrote:
- So true, Fred, I found the site does provide references for the led bulbs that are available for our cars. I could not find the mirror mounted map reading bulbs, for example, on eBay in led but surprisingly enough they were on Amazon. Hardly 20 for $7.00 though. Maybe someday some one will post a cross reference and source for all the weird little bulbs GM used like the one in the Caprice illuminating the headlamp switch or the one in the Roadmaster door illuminating the inside door handle at night. You see them when they work and when you take apart an assembly in a salvage yard. Find a number though...oh well.
Richard Snipes 4501 Safari in Jax, FL the bulb for illuninating the Caprice headlamp switch is a Honda part # 35505S84-NO1 | |
annapolis
| Subject: bulb Thu Apr 16, 2015 3:47 pm | |
Richard Snipes 4501 Safari in Jax, FL that bulb is correct if your switch is like mine in my 1994, rotates, believe at least 95 is the same do not know if all Caprice used the same style switch as mine it rotates to operate, am not knowing what switches were in the below 1994 model caprice bulb # Honda part # 35505S84-NO1 will light it for you. | |
starchaser
Posts : 4 Join date : 2016-01-27
| Subject: LED bulbs Tue Feb 09, 2016 2:11 am | |
| I want to have my reverse lights blink so if I put LED lights in place of regular bulbs and put a stock flasher in line would they flash faster than normal ? I would like to put a strip of LED's on the side of rear lamps. along with a back-up buzzer put in before the flasher I need this as I live near a collage and many people don't pay attention to where they are walking, | |
| Subject: Re: Found an automotive LED replacement bulb source 4/15/2015 Tue Feb 09, 2016 2:23 am | |
| They would not flash at all. You need an electronic flasher. Having your brake lights flash would not help a pedestrian. You are already past them when they see the lights. If you want them to flash when backing, it might make a little difference. It may also be illegal to have them flash while braking depending on where you are living. | |
| Subject: Re: Found an automotive LED replacement bulb source 4/15/2015 Tue Feb 09, 2016 5:54 am | |
starchaser
| Subject: STOP LIGHTS ?? Wed Feb 10, 2016 12:19 am | |
| I didn't mean brake lights just the white lights that come on when you put the car in reverse .buickwagon thanks but I've seen these and want something a little brighter.and can wire some LED strips on the sides of the lenses. | |
starchaser
Posts : 313 Join date : 2010-12-24 Location : Memphis Tn
| Subject: Re: Found an automotive LED replacement bulb source 4/15/2015 | |
