| Stiff turn signal switch | |
autoarcheologist
| Subject: Stiff turn signal switch Wed Jun 24, 2015 7:51 pm | |
| Do the turn signal switches get stiffer with age on these cars? Or were they stiff from the beginning?
Is there a pivot that could be greased?
On our Roady I feel like I have to use so much force to engage the turn signal that I am going to break off the stalk. It is much stiffer than our 2004 Tahoe, or any other car I have driven recently. | |
Wagoninabox
| Subject: Re: Stiff turn signal switch Wed Jun 24, 2015 8:02 pm | |
| I have found them all like that on our wagons. It feels like your are breaking a stalk of celery to turn! | |
| Subject: Re: Stiff turn signal switch Thu Jun 25, 2015 2:40 pm | |
| My turn signal clicks into place, but it is not difficult to move. The switch is all contained in the unit inside of the column. If you replace the switch, it should be a lot easier. The only other possibility is that the pivot in the bezel is binding, but I have not heard of that happening. A little grease on the moving surfaces might help as well. | |
autoarcheologist
| Subject: Re: Stiff turn signal switch Thu Jun 25, 2015 2:46 pm | |
| How hard is it to get that switch out Fred?
Our wipers are also finicky. They sometimes stop when trying to park, and a jiggle of the switch gets them going again. If I'm going to replace the stalk and switch, I might as well pull out the rest and grease it up. | |
Deadmanonduty
| Subject: Re: Stiff turn signal switch Thu Jun 25, 2015 3:10 pm | |
| My dad snapped one off back in the day on his 93 Caprice! He was pissed off and gave it a pound and it didn't like that ! lol
| Subject: Re: Stiff turn signal switch Thu Jun 25, 2015 3:24 pm | |
| The wiper issue is probably the black box on the wiper motor, no sense in replacing the entire stalk. To get to the turn signal switch, you have to remove the steering wheel, clockspring, and lock plate. Once you have the lock plate off, the switch has 3-4 Phillips screws holding it to the column. You do not have to remove the stalk to swap the switch. Once you remove the switch, check the pivot for freedom of vertical movement. If it is free moving, then the switch is the only issue. It should not need a lot of grease, but a little on the moving parts will not hurt it. Use a plastic safe grease. | |
autoarcheologist
| Subject: Re: Stiff turn signal switch Thu Jun 25, 2015 3:50 pm | |
| The wiper issue is definitely the switch. I had to swap the black box to get the intermittent feature back. But the current issue is likely a had connection in the switch. | |
Shnalla
Posts : 45 Join date : 2015-06-04 Location : Lyon, France
| Subject: Re: Stiff turn signal switch Thu Jun 25, 2015 6:12 pm | |
| I have 92 Buick Park Avenue and a 84 Wagon both with the same turn signal and it's pretty stiff. | |
| Subject: Re: Stiff turn signal switch Thu Jun 25, 2015 7:27 pm | |
| Dorman makes a replacement stalk if you want a new one.
| Subject: Re: Stiff turn signal switch | |
