| Locking Hubcap Removal Help... | |
Posts : 3047 Join date : 2010-04-13 Age : 37 Location : Chicopee, MA
| Subject: Locking Hubcap Removal Help... Sun 11 Jul 2010 - 17:02 | |
| My 93 came with locking wire hubcaps with a #21 (?) lug in the center. The owner I bought it from lost it years ago. I've been able to get 3 of the bolts off using pliers. But one will not come off at all. Anyone know any tricks to get it off? Or have one they arent using? Someone on ebay wants $29 for a key. I cant justify spending $29 for something I'll use once.
Thanks | |
scoob8000
Posts : 60 Join date : 2009-10-07 Location : Pittsburgh, PA
| Subject: Re: Locking Hubcap Removal Help... Sun 11 Jul 2010 - 18:31 | |
| You mean the green or beige plastic "nuts"?
Heat up a flat head screwdriver, melt a slit in it. Let the screw driver cool, and unscrew it.. | |
| Subject: Re: Locking Hubcap Removal Help... Sun 11 Jul 2010 - 18:41 | |
| - scoob8000 wrote:
- You mean the green or beige plastic "nuts"?
Heat up a flat head screwdriver, melt a slit in it. Let the screw driver cool, and unscrew it.. No. Its a small appx 1in bolt in the center of the rim which screws into that hubcap dome on the rim You can kinda see the nut in the center. | |
Posts : 7249 Join date : 2009-11-13 Age : 75 Location : Largo, FL 33774
| Subject: Re: Locking Hubcap Removal Help... Sun 11 Jul 2010 - 19:22 | |
| Try drilling a hole in it and use an easyout. Another option is use a left hand drill. 3rd possibility, weld a nut onto the end and turn out with a wrench. Craftsman makes a nut removing set that will grab anything if you can get it in the hole. | |
| Subject: Re: Locking Hubcap Removal Help... Sun 11 Jul 2010 - 19:26 | |
| - Fred Kiehl wrote:
- Try drilling a hole in it and use an easyout. Another option is use a left hand drill. 3rd possibility, weld a nut onto the end and turn out with a wrench. Craftsman makes a nut removing set that will grab anything if you can get it in the hole.
I think i'll try drilling it. But tomorrow I'm going to go to where I got my tires and see if they can pull it. I'll be replacing these hubcaps with N97's so even if they destroy the bolt I wont car, I have the other 3 wheels locked in with hex nuts. | |
| Subject: Re: Locking Hubcap Removal Help... Sun 11 Jul 2010 - 20:50 | |
| Go to the dealer. You can get the correct wrench there, for less than $29... | |
Posts : 3365 Join date : 2008-11-05 Age : 75 Location : Littleton, NH & St. Simons, GA
| Subject: Re: Locking Hubcap Removal Help... Sun 11 Jul 2010 - 20:53 | |
| - jayoldschool wrote:
- Go to the dealer. You can get the correct wrench there, for less than $29...
Jayson I just had to buy the green type, it was $32. Tom C. | |
| Subject: Re: Locking Hubcap Removal Help... Sun 11 Jul 2010 - 20:57 | |
| check thru your metric sockets,. hammer one on it, hammering also loosens the 'grip' by lowering the height of the hupcap slightly as its compressed (read,. "whack it hard!") ,. try pointy vice grips on it after beating it some,.
Nick | |
| Subject: Re: Locking Hubcap Removal Help... Sat 17 Jul 2010 - 21:55 | |
| I got it off. Took me a 7/16 socket, a hammer, a can of WD40 and about 2 dozen good whacks and it finally broke loose. | |
| Subject: Re: Locking Hubcap Removal Help... Sun 18 Jul 2010 - 1:21 | |
| - Cadet57 wrote:
- I got it off. Took me a 7/16 socket, a hammer, a can of WD40 and about 2 dozen good whacks and it finally broke loose.
your welcome,. | |
| Subject: Re: Locking Hubcap Removal Help... | |
