Subject: power window switch? Wed Sep 13, 2023 7:01 pm
So the rocker for the drivers window broke and the window was stuck about 2/3 of the way closed... The window would go down but not back up. Pulled the switch assembly and triggered the switch with a small screwdriver to close the window. Is it possible to replace just the rocker? We may take a trip to the junk yard and see if there are any Caprices there and get a new switch assembly. Or I see Rock Auto has several options for a replacement switch assembly.
BAD_WAG
Posts : 107 Join date : 2022-12-10 Location : Las Vegas
Yes, the little chrome piece can be changed by itself. It just has two little clips on the sides. Always grab a few when I'm at the junk yard since they fit right in your pocket, lol.
rcktpwrd likes this post
They fit all of the paddle switches, although the auto down switch generally has a taller paddle. If the pivot is broken, the black portion can be replaced too.
rcktpwrd
