You need a tone ring for the 3.42 ratio, and the correct pinion shaft. Check with the manufacturer for the correct parts. If you are using the stock posi, the kit should be good. The FSM has the instructions, minus one detail... put some sealant on the pinion shaft splines to avoid oil seepage. You need a pinion shaft holding tool, proper sockets, dial indicator, ft lb torque wrench, micrometer/caliper, and an in lb rotating torque wrench. You can borrow the rest of the tools from AutoZone. Replace the axles and bearings. Moser axles are only about $50 more than the Chinese or Indian made, but will outlast them, and are made in the USA. I have the axel specs for Moser. There are some small details I have not covered, but that is for another day.
