 Inside Door Light
zonaman
6 posters
zonaman
zonaman
Inside Door Light  Empty
PostSubject: Inside Door Light    Inside Door Light  Icon_minitimeFri Oct 25, 2024 12:34 pm
My door light, rear passenger side, will not illuminate. Bulb is good. Other door lights work. Door switch? If yes, where to procure one? Thanks.
PostSubject: Re: Inside Door Light    Inside Door Light  Icon_minitimeFri Oct 25, 2024 1:28 pm
You might check the wire conduit between the door and the body for fraying or cracks.
PostSubject: Re: Inside Door Light    Inside Door Light  Icon_minitimeFri Oct 25, 2024 5:34 pm
Check the wires in the conduit, and work your back until you find voltage. You may still be able to get the switch from your local parts store. If they can not get one, check Rock Auto. All of the switches are the same from 91-96. They may be the same for a much greater span of years and models.
ayilar likes this post
zonaman
zonaman
PostSubject: Re: Inside Door Light    Inside Door Light  Icon_minitimeMon Oct 28, 2024 9:15 pm
Looks like I'll be getting the ol' multimeter out. One thing that confuses me: If the door switch was the issue , and that door alone was opened, would it only effect just that door light or would none of the interior lights come on?
PostSubject: Re: Inside Door Light    Inside Door Light  Icon_minitimeTue Oct 29, 2024 8:30 am
All of the lights will come on .
booster
PostSubject: Re: Inside Door Light    Inside Door Light  Icon_minitimeTue Oct 29, 2024 11:44 am
Is there a standalone light control module in our wagons, or is built into the Body control module
Either way, you are just sending a signal from the switch to the module and module turns on all the lights.
A lot more wiring and stuff the go wrong than just power to the switch to the light the old school systems were.
I had corroded, loose, connections on a couple my switches when I got the RMW. Tightened up the connections and some contact cleaner took care of it without replacing.
PostSubject: Re: Inside Door Light    Inside Door Light  Icon_minitimeTue Oct 29, 2024 11:50 am
There is no body control module in the 91-96 B body cars. Just a relay.
booster
PostSubject: Re: Inside Door Light    Inside Door Light  Icon_minitimeTue Oct 29, 2024 11:53 am
Is it a time delay off relay, or how do they do the stay on timer?
PostSubject: Re: Inside Door Light    Inside Door Light  Icon_minitimeTue Oct 29, 2024 1:48 pm
The only time there is a time delay is when you use twilight sentinel after turning the engine off.
booster
PostSubject: Re: Inside Door Light    Inside Door Light  Icon_minitimeWed Oct 30, 2024 9:45 am
That is interesting as the owner's manual seems to indicate all the Roadmasters have a 30 or 40 second delay for the interior lights depending on if you just open the door or use the remote unlock. The manual also seems to only be referencing the headlights going to automatic vs manual control/
PostSubject: Re: Inside Door Light    Inside Door Light  Icon_minitimeWed Oct 30, 2024 10:16 am
The remote has its own time delay.
booster
PostSubject: Re: Inside Door Light    Inside Door Light  Icon_minitimeWed Oct 30, 2024 1:04 pm
On my 96 I don't use the Twilight sensor so it is off.
The lights do come on with delay when I remote unlock the doors and stay on until started or about 30 seconds.
If I open a door from inside or outside the car even with FOB in the house my in the remote garage, the lights come on and stay on even after the door closed.  I see this all the time when I am working on the car.
This appears to be just as the owner's manual states, to me.
Inside Door Light  Indide10
Inside Door Light  Twilig10
94Woody likes this post
PostSubject: Re: Inside Door Light    Inside Door Light  Icon_minitimeWed Oct 30, 2024 1:13 pm
I have a Caprice wagon, no twilight sentinel and no remote unlock. When you open the doors, door lights and overhead lights stay on for about 30 seconds.
PostSubject: Re: Inside Door Light    Inside Door Light  Icon_minitimeWed Oct 30, 2024 9:26 pm
Tom is correct. Booster is correct. That owners manual is correct. I can go outside and make some videos showing the interior lights on both the 95 without TS and the 96 with TS staying on for 30-40 seconds after all the doors are closed if anyone else needs further clarification. Wink
silverfox103 likes this post
booster
PostSubject: Re: Inside Door Light    Inside Door Light  Icon_minitimeThu Oct 31, 2024 8:23 am
Thanks Woody, I have been looking through the so very poorly laid out factory service manual for actual schematics to see where the wires all wind up. The manual splits up stuff so badly in chunks and then indexes them terribly so hard to get a good look quickly.
It appears that the delay from remotes is in the remote lock control module in the left rear wheel well and the Twilight is headlight delay as suspected.
The signal from the door switches looks to go to Convenience Control Center which I expected would be small control module of electronics but appears to only be a relay block for plug in relays. Stated to be in the left side front kick panel area.
The parts lists only show a, IIRC, 5 pin relay, so the opening of door time delay must be inside of that relay as I saw no other items like a standalone delay.
None of this changes the OP's problem with one door not doing it's job, but at least let's him know how it works and where to look for the problem. Since the other doors work, the relay works, so that leaves just the switch and wiring. As mentioned earlier, or switches had a couple them with loose, corroded connections and cleaning them up and tightening took care of our similar issue.
PostSubject: Re: Inside Door Light    Inside Door Light  Icon_minitimeSat Nov 02, 2024 3:34 pm
While I always recommend people with these cars have the FSM on hand, they aren’t perfect. The wiring stuff is a big PITA.
zonaman
zonaman
PostSubject: Re: Inside Door Light    Inside Door Light  Icon_minitimeSat Nov 09, 2024 12:14 pm
Thanks to all who have posted. Most "enlightening!" I'm the middle of a move so the wagon stuff gets pushed back. I picked up a door switch, just in case, and as soon as I come up for air, I'll get to it and post where the problem was.
zonaman
zonaman
PostSubject: Re: Inside Door Light    Inside Door Light  Icon_minitimeMon Dec 16, 2024 4:21 pm
Okay, finally got a multimeter on it. Turned out it was unplugged. My guess is previous owner did some work, fixed a window regulator or something, didn't plug it back in or didn't realize it came loose.
rcktpwrd likes this post
Inside Door Light
» Looking for light bulbs for RMW door panels and map light
» Door light switches
» Door light bulb -- help needed
» Door panel armrest light question???
» Found this laying inside rear door, is it a window guide broken off?
