| Subject: Interior lights STAY ON!!! Help Fri Dec 24, 2010 7:39 am | |
| All of the mighty hunters helped their dad clean out the car yesterday after returning home. One of them left the driver side rear door open. I went out about 11 pm to close things down for the night and discovered a car with a dead battery. I put my charger on it and everything came back. The problem is now the dome/interior lights will not turn off. I pulled a fuse and went to bed.
Need to get this one solved right away!! Anyone seen this issue?
Last edited by BigBlackBeaSSt on Fri Dec 24, 2010 3:04 pm; edited 1 time in total | |
DBeaSSt Admin
| Subject: Re: Interior lights STAY ON!!! Help Fri Dec 24, 2010 9:19 am | |
| Perhaps an obvious thing. But did someone turn the interior light knob all the way by mistake? | |
| Subject: Re: Interior lights STAY ON!!! Help Fri Dec 24, 2010 10:28 am | |
| Thanks Mike, but that is not it. I swapped the relays around with the Impala and they are working fine. The FSM says to remove the Alarm. It does not want to come out. Any one remove one? Does it have a tab on the back? How does one release this tab? | |
| Subject: Re: Interior lights STAY ON!!! Help Fri Dec 24, 2010 10:59 am | |
| Got the alarm out. The interior lights go on when the headlight switch is turned to the left at all times. But they do not come on when you just open the doors!?!??!? | |
| Subject: Re: Interior lights STAY ON!!! Help Fri Dec 24, 2010 11:17 am | |
| Sounds like the door light switch has fried and is stuck in the on position. My 2 Cents Jim Gordon |
| Subject: Re: Interior lights STAY ON!!! Help Fri Dec 24, 2010 12:38 pm | |
| Door jam switch. Removed - played with - worked..... done!! | |
| Subject: Re: Interior lights STAY ON!!! Help | |
