| radio shack variable resistor to fix gas gauge? | |
44whoo
Posts : 39 Join date : 2011-02-17 Location : NYC
| Subject: radio shack variable resistor to fix gas gauge? Sun Jul 17, 2011 8:31 pm | |
| can i splice a variable resistor into my fuel gauge wire to make the gauge more accurate? if i can how would it be done?the part from radio shack has 3 prongs and i think i only need 2. i saw the mod where you add more resistance to the sender but i dont want to remove it just for that if i can just splice a wire and have 90% of the accuracy.thanks-dave | |
Nick Danger
| Subject: Re: radio shack variable resistor to fix gas gauge? Sun Jul 17, 2011 9:59 pm | |
| It's pretty easy. Get a 0-1000 ohm 20-turn trimpot resistor. You want 20-turn, because the sweet spot is kind of small for 10-turns. When the screw is in the center position, it should be about 500 ohms from the side pin to the center pin. Once you have that, cut off the third pin and solder some wires to the pins you have left. You can put heat shrink over the result. I just wrapped everything with tape to protect the pins. You'll want to put a crimp-on ring terminal on the ground wire. I think it's a quarter inch. Then follow the directions here: http://www.fuelgaugecalibrator.com/bbody/Instructionsbbody.htmlMy result was that the gauge reads F when the tank is full, and E when it the tank is empty. My low-fuel light didn't illuminate until the tank was completely empty, and the engine was sputtering. That isn't a big deal for us, because we refill at 1/4 tank anyway.
Last edited by Nick Danger on Sun Jul 17, 2011 10:02 pm; edited 1 time in total | |
| Subject: Re: radio shack variable resistor to fix gas gauge? Sun Jul 17, 2011 10:02 pm | |
44whoo
| Subject: Re: radio shack variable resistor to fix gas gauge? Tue Jul 19, 2011 8:36 pm | |
| thanks for the quick replies, at the local radio shack i found a 15 turn resistor will it work or will i have to go to another r.s.?also the instructions that was linked in the replies were not complete,does anyone have a complete walk thru?thanks! dave | |
| Subject: Re: radio shack variable resistor to fix gas gauge? Tue Jul 19, 2011 8:55 pm | |
| The 15 turn will work just fine..
I've found out the hard way that the secret is not about having your gauge be accurate when your tank is full.
The real secret is having the gauge be accurate when it is empty.
Nick Danger
| Subject: Re: radio shack variable resistor to fix gas gauge? Wed Jul 20, 2011 1:56 pm | |
| - 44whoo wrote:
- thanks for the quick replies, at the local radio shack i found a 15 turn resistor will it work or will i have to go to another r.s.?also the instructions that was linked in the replies were not complete,does anyone have a complete walk thru?thanks! dave
I thought that the instructions were pretty good. What is left out? | |
| Subject: Re: radio shack variable resistor to fix gas gauge? Wed Jul 20, 2011 6:26 pm | |
| It's a matter of simply hooking up the new resistor in parallel with the old one. The wire is purple and runs along the drivers door sill. Peel back the rug under the hood release lever and you'll find it.. | |
44whoo
| Subject: Re: radio shack variable resistor to fix gas gauge? Wed Jul 20, 2011 9:49 pm | |
| guy's i'm sorry that i asked for better instructions,i first looked at the link and only saw the pic of the 1st page of instructions.now that i see the full instructions it looks real easy.i hope to do the install this weekend. thanks | |
| Subject: Re: radio shack variable resistor to fix gas gauge? Thu Jul 21, 2011 7:16 am | |
| no problem, just show up for Wagonfest. You are in the same state!
..... and bring BEER! | |
44whoo
| Subject: Re: radio shack variable resistor to fix gas gauge? Tue Jul 26, 2011 4:13 pm | |
| i installed the resistor yesterday,it seems to be working great.thanks for the help! | |
| Subject: Re: radio shack variable resistor to fix gas gauge? | |
