So my low oil level dummy light was on for the longest.. Everytime I did my oil change I forgot to buy the sensor.. So I finally did on wendsday night.. When I rebuilt my engine I remember seeing a cylinder type peice when I took it out the oil pan.. So when I pulled it out I did not see it this time.. Instant thought was F*!!!!.. I have to drop my oil pan..
Not bad at all.. Remove oil cooler lines.. Remove tranny line bracket bolted to the oil pan bolt.. Drop your Y-pipe.. And your good to drop it.. 1/4" swivel.. Best friend!.. I borrowed my buddy's cherry picker to raise the engine.. So therefor you gotta take off the top fan shroud peice.. Fairly simple..
So I have this pan down.. Take peak inside.. Nothing!.. Then it hits me.. Last oil change something clumpie came out.. And I was thinking sludge already in a fresh engine.. But it was most likely that cylinder peice..
Figured I'd share my anger story for my weekend..
