 auto tranny problems
auto tranny problems Empty
PostSubject: auto tranny problems   auto tranny problems Icon_minitimeWed Oct 14, 2009 8:49 pm
i changed the tranny in the old gold roady agaian now its in limp mode ,.
i can seem to find out where the fuse is for the tranny any one know>? car was driving down to the shop with the pooched trans ,. and one of the ecm plugs wasn't plugged in properly and came out,. the car puked,.so i shoved it down to the shop and on the hoist with the neighbours pickup,.
changed the trans,. now its in limp mode,.
I replaced the short spring in the lockup valve with a much longer one to keep the valve at its fullest travel (95 trans into a 94 car)
but i must have blown the fuse?? but i can't find one that says transany where,..
PostSubject: Re: auto tranny problems   auto tranny problems Icon_minitimeWed Oct 14, 2009 9:04 pm
Hang on, I'll go out to the garage and get the FSM...
Ok, I'm back.
In the FSM, "third gear only" says to inspect the following:
- Codes:
- 52 long system voltage high
- 53 system voltage high
- 66 3-2 control solenoid circuit fault
- 75 system voltage low
- 81 2-3 shift solenoid circuit fault
- system voltage
- 3-2 control solenoid
Haven't found the fuse(s) for the trans yet. If I had to guess, there isn't one. It is probably fused with the PCM. Check all the fuses in the underhood box with the relays.
PostSubject: Re: auto tranny problems   auto tranny problems Icon_minitimeWed Oct 14, 2009 10:20 pm
The only fuse that specifically mentions the trans is #15 in the underhood fuse box, but it also controls the coil, ecm etc. This is the description:
15 - PCM IGN (10 AMP)
- IGN COIL
- ELECTRONIC TRANS.
- (PCM) POWER TRAIN
CNTRL. MDL.
Hope this helps
PostSubject: Re: auto tranny problems   auto tranny problems Icon_minitimeWed Oct 14, 2009 10:57 pm
It's definitely underhood. It also powers the O2 sensors and the MAF. Forgive me for being obtuse but my FSM's are misplaced and I'm just going off of memory here.
PostSubject: Re: auto tranny problems   auto tranny problems Icon_minitimeThu Oct 15, 2009 10:25 pm
K,. 'preciate the trys etc,. BUT,. if the pcm fuse is blown the car don't run,..
so i guess drop the forkin pan AGAAIN, and check solenoids,.????
now i,m askeered to drop the black cars tranny pan for fear of it not working ever again,......
AAAAAARGH!!!! i wish it would lock up,. GRRRRR
charging up the battery on the camera,..
» Tranny coming out again!! :(
» Tranny upgrade
» Tranny problem
» 350 Tranny question - HELP!!!!!!!
» Whirring Sound Problem with Tranny or Something Else
