| Oil level connector | |
VT Wagon
Posts : 100 Join date : 2014-11-16 Location : Central Vermont
| Subject: Oil level connector Mon Jan 05, 2015 7:52 am | |
| I can't find the connector. Is it up the harness or should it be at the switch? Same with the o2 sensor.
Any advice appreciated.
Thanks, Jon | |
JaySS Admin
| Subject: Re: Oil level connector Mon Jan 05, 2015 9:55 am | |
| - VT Wagon wrote:
- I can't find the connector. Is it up the harness or should it be at the switch?
Thanks, Jon The connector is inside the sensor hex. Locate the access hole on top of the sensor. Using a right angled pick, lift the retaining clip and the connector may then be pulled free. Since you can’t see the connector once it is installed, reference the coolant temp sensor on the water pump to see what you are trying to do. The O2 sensor connections are the flat 4 pin connectors on the side of the block near the knock sensors. - J | |
HoosierDaddy
Posts : 102 Join date : 2014-12-28
| Subject: Re: Oil level connector Mon Jan 05, 2015 11:03 am | |
| The downstream oxygen sensor connectors are on the side of the transmission on a '96. | |
VT Wagon
| Subject: Re: Oil level connector Mon Jan 05, 2015 6:17 pm | |
| Thanks guys, that's a big help. | |
VT Wagon
| Subject: Re: Oil level connector Mon Jan 05, 2015 7:09 pm | |
| Alright, I found the O2 connector. Still not clear on the oil level switch. [You must be registered and logged in to see this link.] | |
| Subject: Re: Oil level connector Mon Jan 05, 2015 11:53 pm | |
| The tab to release the connector is inside that brass hex of the switch. Look at it from the end. You will need a small screwdriver to release the tab. Simultaneously, pull the connector out of the switch. | |
| Subject: Re: Oil level connector Sun Jan 25, 2015 3:00 am | |
| The little orange-handled 90 degree pick from the Harbor Freight mini-pick set is perfect to get that connector off. | |
71novaguy
| Subject: Re: Oil level connector Sun Jan 25, 2015 8:29 pm | |
| and now that its out, it will probably leak. smart money says put in a new one. | |
| Subject: Re: Oil level connector | |
