 1995 Roadmaster Water Pump Pulley Bolts
Schoolzin
1995 Roadmaster Water Pump Pulley Bolts Empty
PostSubject: 1995 Roadmaster Water Pump Pulley Bolts   1995 Roadmaster Water Pump Pulley Bolts Icon_minitimeMon Jun 01, 2020 12:55 am
Hey guys, I’m in need of some help. I’ve misplaced the three bolts that attach the water pump pulley to the harmonic balancer on my LT1. I have the tow package, so it’s a mechanical fan. Can someone tell me exactly what size those dang things are? Thanks!
Sean
PostSubject: Re: 1995 Roadmaster Water Pump Pulley Bolts   1995 Roadmaster Water Pump Pulley Bolts Icon_minitimeSun Jun 14, 2020 12:53 pm
I would PM Fred Kiehl.
Schoolzin likes this post
Schoolzin
PostSubject: Re: 1995 Roadmaster Water Pump Pulley Bolts   1995 Roadmaster Water Pump Pulley Bolts Icon_minitimeMon Jun 29, 2020 2:30 am
Unfortunately I don’t seem to have reached the post limit in order to send PMs. Hmmm....if anyone sees this can they forward this question to him? I would greatly appreciate it!!!!
PostSubject: Re: 1995 Roadmaster Water Pump Pulley Bolts   1995 Roadmaster Water Pump Pulley Bolts Icon_minitimeTue Jun 30, 2020 3:32 pm
just make a couple more posts and you will
sdowney717
PostSubject: Re: 1995 Roadmaster Water Pump Pulley Bolts   1995 Roadmaster Water Pump Pulley Bolts Icon_minitimeSun Oct 11, 2020 10:06 am
The wrench used on the nuts holding the fan on to the bracket bearing is 1/2" or 13mm used with the tow package
the four studs are maybe 1.25 inch long. I dont think these are metric studs
There is no water pump pulley on an LT1, it is driven directly off  an internal gearing under the front engine cover
I think you mean the main engine pulley attachment of 3 bolts to the engine adapter the slides onto the crankshaft, and dont know what size they are, but easy enough to figure it out.
» New water pump, leaking upper bolts
» Which Water Pump
» Yet another water pump issue
» water pump on LT1
