 Fuel Pump for '93 Caprice SW
Guy Newport
Guy Newport
Fuel Pump for '93 Caprice SW Empty
PostSubject: Fuel Pump for '93 Caprice SW   Fuel Pump for '93 Caprice SW Icon_minitimeTue Jan 18, 2022 3:00 pm
Ok, I'll admit I went out a bit on a limb when I ordered my Delphi HP10030 Fuel Pump & Hanger assembly. The listing didn't specify "SW" but it did list the same assembly for a '93 RMW so I took the plunge. Wrong-O. I'm sure many of you know of the difference in the length of tubes & the gauge wire running over the top of the tank; the ones that are Way Short when considering this Delphi part number, that is.
1. The rig has 186K +/- on it so I was gonna replace the entire unit. Is there one available that's '93 Caprice SW specific?
2. It's likely the answer to the first question is "No" so....what assortment of parts from what source would any of you recommend to select the pieces to give mine the ol' preventative maintenance attention I'd like to administer?
I'll install the HP10030 in my '93 Roadmaster so the pump assy won't go to waste but what a lotta shuffling at this stage of the game!
» F**ck#n fuel pump (again)
» 94-96 Fuel Pump Ground
» replacement fuel pump
» Need help with a fuel pump
» what fuel pump?
