Subject: VATS and FUEL PUMP Tue Aug 02, 2022 12:30 pm
Hello, I have a 94RMW with 130,000 miles on it that has been well maintained. I read threads on here of Fuel pump failure where you have to drop the gas tank and it is such a PITA. Is it inevitable? I assume mine is the original pump and it gets driven about five or 6000 miles a year. (New filter around 100k) Is there any preventive care I can do to ensure its longevity?
I have a similar question about the VATS. I am using the original key with the chip in it and it works fine. but if it fails, I’m screwed. Can I nip it in the bud and disable it? I know I have read on here about how to do it but it sounds quite complicated and I am not at all good with anything electronic. Is there some really really simple disconnect I can do? Is failure of the system in evitable? I’m still using that original key I think and it works fine. Also it has been so long since I have used the key to unlock the door that it doesn’t turn in the lock and it feels like I might break the key off…. how can I remedy that? spray some lubricant in there? Or???.
I appreciate any input here. I value this forum highly and have learned a lot from it. Someday I hope to be able to contribute some helpful information but for now I always just have more questions. Thanks so much!
Anthony
Subject: Re: VATS and FUEL PUMP Tue Aug 02, 2022 12:57 pm
Dropping the fuel tank is NOT a very hard task and can be done fairly quickly and easily. That statement can change depending upon the age and condition of the person doing the job. Northern cars that are driven year round can also change things.
Disabling VATS is also a simple task. Just have to unplug the module and ground two wires together. After that it requires a laptop, ALDL cable with tuning software and the software needed to download/unload the bin file from the PCM. I have all of that if you happen to live in central FL.
If the system works I wouldn’t worry too much about it but yes it could be a ticking time bomb. Most failures are related to the key itself or the wires on the key switch itself though.
Subject: Re: VATS and FUEL PUMP Tue Aug 02, 2022 1:22 pm
The Achilles Heel of the fuel pump is the outflow hose. Do a search on this site and you will find some good info regarding the best pumps. Watch a video on disconnecting the quick release hoses and use a board on a jack to lower it slowly. It shouldn't take you more than a morning to finish.
roadsurfer
Posts : 64 Join date : 2011-02-27
Subject: Re: VATS and FUEL PUMP Tue Aug 02, 2022 1:46 pm
Thank you WalterF and 94 Woody…. I guess I will deal with the gas tank when it happens. I just remember reading of someone who said they had to cut out something off the top of the tank to get the pump out or something… My car is mostly a Florida car with minor surface rust on the undercarriage and the tank straps look OK to me.
And 94 Woody, I would be happy with your help. I live in Gainesville just north of you somewhere. What sounds like “a simple task“ (for you) is something I don’t know how to do, using software etc. how can I reach you? My number is 352-284-7873. You could text me there if you’d like.
Thank you so much, Anthony
94Woody and Serendipity96 like this post
Subject: Re: VATS and FUEL PUMP Tue Aug 02, 2022 10:55 pm
Wrote your number down and will send a text at some point. Wagon is in pieces in the garage and I need to get it finished. You aren't far from me at all. It's a pretty quick task, less than an hour altogether.
roadsurfer
Subject: Re: VATS and FUEL PUMP Wed Aug 03, 2022 12:31 am
Fabulous! Thanks so much!
Subject: Re: VATS and FUEL PUMP Wed Aug 03, 2022 11:18 am
Yeah I need to do that too btw....
Subject: Re: VATS and FUEL PUMP Wed Aug 03, 2022 12:23 pm
Since we have the same year yours will be even faster because I already have a tweaked BIN from my car.
Sprocket likes this post
Podor
Posts : 3 Join date : 2022-07-31
Subject: Re: VATS and FUEL PUMP Sat Aug 06, 2022 11:18 pm
I recommend no ethanol fuel if you can get it. The ethanol is very hard on the entire fuel system, including the rubber lines and seals. No ethanol fuel much more stable if you don't drive often.
The VATS isn't too bad. The main issues are the thin wires in the ignition tumbler can fatigue a d break and the resistor in your key and be damaged. Neither are a big deal.
Subject: Re: VATS and FUEL PUMP Sat Aug 20, 2022 7:45 pm
when i was looking at a wagon for sale a few years ago for 1500 - was in decent shape but needed a fuel pump - so i went on YT and there's a guy doing the job on a sedan - basically same job I believe - wasn't fun from the crawling under car without a lift and the gas part, but it didn't look too bad for a novice. His biggest issue was the straps were very rusty - so if yours aren't that's a plus. I would sporadically have issues with my 96 wagon's key - sometimes you just need to clean it and the ignition of any grime and dirt as after a while between getting worn out, the dirt will cause the 'no start/no passkey' issue.
Ethanol fuel--- $$$ or replace fuel lines with SS $$$$ - neither choice is easy on the wallet.
roadsurfer
Subject: Re: VATS and FUEL PUMP Sun Aug 21, 2022 6:49 pm
