 '96 Roadmaster Wagon front signal bulb replacement
ckamin
'96 Roadmaster Wagon front signal bulb replacement Empty
PostSubject: '96 Roadmaster Wagon front signal bulb replacement   '96 Roadmaster Wagon front signal bulb replacement Icon_minitimeThu Feb 09, 2023 9:36 pm
Good evening! Hey I have a front, right side signal bulb that must be burned out. It is not the signal bulb in the headlamp assembly but rather the bulb in the separate lens assembly adjacent to the headlamp (in my case, front right).
The bulb access didn't appear obvious from under the hood and I didn't want to try and pry the lens away if it isn't meant to be accessed in that manner.
How do I go about accessing the bulb/socket assembly?
Thanks!
PostSubject: Re: '96 Roadmaster Wagon front signal bulb replacement   '96 Roadmaster Wagon front signal bulb replacement Icon_minitimeThu Feb 09, 2023 10:04 pm
There is a Phillips head screw above the marker light that must be removed to access the rear of the marker capsule.
ayilar likes this post
ckamin
PostSubject: Re: '96 Roadmaster Wagon front signal bulb replacement   '96 Roadmaster Wagon front signal bulb replacement Icon_minitimeFri Feb 10, 2023 9:10 pm
Thank you! Worked like a charm and saved me from trying other stupid means of removing the lens.
PostSubject: Re: '96 Roadmaster Wagon front signal bulb replacement   '96 Roadmaster Wagon front signal bulb replacement Icon_minitimeSat Feb 11, 2023 8:34 am
Fred is our go-to guy.
Reverend Bob
ayilar and GeoffB like this post
» Roadmaster, Front clip, sedan VS wagon
» Headlamp bulb replacement question...
» Need some help with Rearview Mirror Bulb Replacement
» 1996 Roadmaster Wagon Front Door Trim
» Front bumper chrome trim on Roadmaster wagon
