 Brake bleeding/flushing tips- advice!!
ckamin
Brake bleeding/flushing tips- advice!! Empty
PostSubject: Brake bleeding/flushing tips- advice!!   Brake bleeding/flushing tips- advice!! Icon_minitimeSun Feb 12, 2023 1:32 pm
Happy Sunday! As the new owner of a '96 Roadmaster, one of the things I'll be doing is changing all the fluids (low mileage car but no service history known).
I have a few questions about bleeding the brakes... How accessible are the bleeders? Is it easiest to put the front of the car on jack stands, remove the front wheels, and turn the wheels to most easily access the front brake bleeders? What about the back- jack stands on the frame to let the rear end sag or on the rear end axle tubes? Does it matter?
Any advise to help out would be greatly appreciated. Also, since the car has ABS, is this gonna put the process out of my league? I've bled plenty of brakes on vehicles without ABS but don't want to mess anything up.
Thanks!
Carl
goldwolfnhn
PostSubject: Re: Brake bleeding/flushing tips- advice!!   Brake bleeding/flushing tips- advice!! Icon_minitimeSun Feb 12, 2023 2:02 pm
as long as you don't let air get into the system, or have some in it already, ABS shouldn't be an issue, but from my experience even with my trucks it is generally easier to just jack up and remove the tires, for the rear it would probably be best to jack on the differential and support that, as these cars do have alot of suspension travel, and if you position the jack right you can lift both front or both rear tires at the same time. Front, right in the middle of the cross member behind the support rods, as then they hold the head of the jack and keep it from slipping too much, on the rear, right under the middle of the pumpkin.
ckamin
PostSubject: Re: Brake bleeding/flushing tips- advice!!   Brake bleeding/flushing tips- advice!! Icon_minitimeSun Feb 12, 2023 2:19 pm
Thank you! On the front of the vehicle, where is the best place to place the jack stands themselves? Under the frame rails behind the front wheels after raising the vehicle with a hydraulic jack? I trust hydraulic jacks to raise the vehicle but not enough to be under the vehicle and risk getting killed should the jack fail... I know, I'm no fun...
rcktpwrd
rcktpwrd
PostSubject: Re: Brake bleeding/flushing tips- advice!!   Brake bleeding/flushing tips- advice!! Icon_minitimeSun Feb 12, 2023 3:21 pm
I usually put the stands just behind the front wheels at the curve in the frame.
» brake bleeding
» im new and looking for some tips and advice on my wagon
» Pressure Bleeding the brakes ?
» Bleeding the Cooling System
