| oil cooler delete | |
+394Woody silverfox103 bcreasy 7 posters |
bcreasy
Posts : 84 Join date : 2011-05-14 Location : Indaina
| Subject: oil cooler delete Tue Jun 07, 2011 7:53 pm | |
| Mine cooler lines are leaking so help the newbie out. I know I need a new filter adapter any one have a spare? Once I swap out the adapter what do I do about the lines that go into the radiator? Should I swap out radiators?
Thanks Beau | |
| Subject: Re: oil cooler delete Tue Jun 07, 2011 7:56 pm | |
| Hi Beau
I have eliminated the coolers on two wagon, soon to be three. After you have swapped the coolers, just remove the lines and that's it. Your radiator is fine.
Tom C. | |
bcreasy
| Subject: Re: oil cooler delete Tue Jun 07, 2011 7:58 pm | |
| Thanks Tom Any one have a spare adapter for sale? I have no pap local | |
| Subject: Re: oil cooler delete Wed Jun 08, 2011 12:25 am | |
| I have an extra one of them, $20 shipped. PM if interested. | |
| Subject: Re: oil cooler delete Sun Jun 19, 2011 10:13 am | |
| I just did this mod yesterday. Much happier already..... | |
bcreasy
| Subject: Re: oil cooler delete Sun Jun 19, 2011 10:17 am | |
| - Sprocket wrote:
- I just did this mod yesterday. Much happier already.....
What did you do to the lines running into the radiator? Pics? | |
| Subject: Re: oil cooler delete Sun Jun 19, 2011 10:37 am | |
| - bcreasy wrote:
What did you do to the lines running into the radiator? Pics? Remove them, they serve no purpose. Tom C. | |
| Subject: Re: oil cooler delete Sun Jun 19, 2011 11:50 am | |
| Anyone else have an adapter for sale? My RMW is leaking from the adapter, the lines, and now the rad has a leak. Perfect time to rip that stuff out and put a 9C1 radiator in there, those don't have the oil cooler. | |
| Subject: Re: oil cooler delete Sun Jun 19, 2011 2:03 pm | |
| Hey Tom really like the wheels and grill on the Caprice.Makes it jump out at you! But whitewalls ? Come On Buddy whatever rocks your boat! |
| Subject: Re: oil cooler delete Mon Jun 20, 2011 7:55 pm | |
| Hey Flash
You're observant as I just changed that picture yesterday. It is real similar to the old picture. I know a lot of guys either like or dislike the white walls. They'll probably stay for a while, sorry.
Tom C. | |
| Subject: Re: oil cooler delete Mon Jun 20, 2011 7:58 pm | |
| Did you change the wheels on the RMW? |
| Subject: Re: oil cooler delete Mon Jun 20, 2011 8:01 pm | |
| Both cars have Florida N97 wheels I got from Sprocket. Painted silver, chrome rings, N97 center caps with either Buick or Chevy two flags decals in the centers. Oh, and white walls to finish them off.
| Subject: Re: oil cooler delete Mon Jun 20, 2011 8:25 pm | |
| Back on topic (although the N97s look great in silver) I removed the lines completely.
| Subject: Re: oil cooler delete Mon Jun 20, 2011 8:38 pm | |
| Sorry John Didnt mean to do that to you.Its just that when I see a change I cant help but to zero in on it. |
rkmdogs
Posts : 179 Join date : 2011-03-23 Location : Lakeland, FL.
| Subject: Going the other way--- adding oil cooler! Thu Oct 27, 2011 9:21 am | |
| Some interesting comments about removing coolers, but I plan to go the other way! As a former 9C1 owner, I think the coolers are very beneficial to the longevity of the power train. So, I was going to add the 9c1 police car coolers to my wagon ----- until I discovered a weird factory modification! My wagon was built without the additional external coolers, but what they did was plumb the trans thru the radiator cooler on the right side, and then over to the cooler on the left side of the radiator, and then back to the trans! Since this use of a double cooler was built in, I decided that the addition of an external trans cooler would be overkill, but I intend to add the external engine oil cooler. So, I bought a 1995 9C1 cooler on ebay. Then found out that all the factory lines for the coolers have been discontinued. Meanwhile, I also acquired a 1994 oil filter adapter --- and then discovered that the factory had made plumbing changes between the two years! The '94 system had individual connectors at both ends, with American threads. The '95 system has a monoblock fitting at the oil filter adapter, like the A/C compressor, and these are metric threads! So, my plan now is to get some custom lines made to use the parts that I have acquired. Bummer, but possible for $$$$$$! | |
| Subject: Re: oil cooler delete Thu Oct 27, 2011 9:47 am | |
| They discontinued the LT1 cooler lines?
Weird, I got new lines for my '92 last summer from the dealership just fine. Wonder why they would do that. |
rkmdogs
| Subject: Re: oil cooler delete Thu Oct 27, 2011 11:31 am | |
| - Stingroo wrote:
- They discontinued the LT1 cooler lines?
Weird, I got new lines for my '92 last summer from the dealership just fine. Wonder why they would do that. Vehicle age obviously. When I checked my source, some dealerships had one line only, but not both! That's even weirder! Then I also found out that the individual fittings version was from '93 but those lines don't work in the later bodies--- if you could even find them! | |
| Subject: Re: oil cooler delete Thu Oct 27, 2011 11:43 am | |
My 94 had the mono block setup on it from the factory. I still have the adapter and lines in the garage. Would sell it all if you need it. The lines are from Dorman and were used for about a year and only a few thousand miles. | |
rkmdogs
| Subject: Re: oil cooler delete Thu Oct 27, 2011 12:12 pm | |
I still have the adapter and lines in the garage. Would sell it all if you need it. The lines are from Dorman and were used for about a year and only a few thousand miles. For the oil cooler or the trans cooler? Send me an e-mail with your price, please! Include a pic of the stuff if you can. [You must be registered and logged in to see this link.] | |
| Subject: Re: oil cooler delete Thu Oct 27, 2011 1:54 pm | |
| Well of course, but I'm saying it's odd that they discontinued the LT1 lines but not the TBI lines. I didn't even have to wait, they had a set right on the shelf.
Maybe I got lucky. |
rkmdogs
| Subject: Re: oil cooler delete Thu Oct 27, 2011 6:54 pm | |
| - Stingroo wrote:
- Well of course, but I'm saying it's odd that they discontinued the LT1 lines but not the TBI lines. I didn't even have to wait, they had a set right on the shelf.
Maybe I got lucky. You probably did, or the dealer appreciated you removing old stock that he was "stuck" with! | |
patgizz
Posts : 51 Join date : 2011-09-21 Location : Cleveland, OH
| Subject: Re: oil cooler delete Thu Oct 27, 2011 9:52 pm | |
| i'm deleting mine on the 94. new adapter/gasket/bolts is $20 at summit. i have a brand new set of lines for lt1 cooler if anybody needs them cheap. i have had plenty of 200K+ mile small blocks that did not have oil coolers. trans on the other hand, i'm a believer in you can almost never have enough trans cooling capacity ever since i saw a chart between trans temp and how exponential part wear increase is for every 10 degree increase in temp | |
rkmdogs
| Subject: Re: oil cooler delete Fri Oct 28, 2011 8:56 am | |
| - patgizz wrote:
- i'm deleting mine on the 94. new adapter/gasket/bolts is $20 at summit. i have a brand new set of lines for lt1 cooler if anybody needs them cheap. i have had plenty of 200K+ mile small blocks that did not have oil coolers. trans on the other hand, i'm a believer in you can almost never have enough trans cooling capacity ever since i saw a chart between trans temp and how exponential part wear increase is for every 10 degree increase in temp
Please PM me with a pic--- I am very interested, if they are for the air-cooled cooler. A lot of them had the water-cooled variety, like what was on the F-bodied cars. That is not the same as what was used on the 9C1 optioned cars. You can send the info -- and price request to: [You must be registered and logged in to see this link.]Thanks for a speedy reply. | |
rkmdogs
| Subject: Re: oil cooler delete Sat Oct 29, 2011 10:35 am | |
I still have the adapter and lines in the garage. Would sell it all if you need it. The lines are from Dorman and were used for about a year and only a few thousand miles. I'm interested but need to see what you have. Can you either post some pics, or send them to me via P/M? | |
| Subject: Re: oil cooler delete Sat Oct 29, 2011 8:18 pm | |
| I have the adapter for the engine and the lines from the adapter to the Cooler inside the radiator. I can get pics of the parts if needed but must dig them out, lol. | |
rkmdogs
| Subject: Re: oil cooler delete Sun Oct 30, 2011 9:42 am | |
| - 94Woody wrote:
- I have the adapter for the engine and the lines from the adapter to the Cooler inside the radiator. I can get pics of the parts if needed but must dig them out, lol.
It sounds like what you have is what was used on the "F"bodied cars,(Camaro & Firebird). This is a water-cooled system, not the air-cooled style used on the police car options. That's why I need to see pics of what you have. Thanks | |
patgizz
| Subject: Re: oil cooler delete Sun Oct 30, 2011 5:10 pm | |
| the ones i have are for the wagon- in radiator cooler not 9c1 ones. | |
| Subject: Re: oil cooler delete Sun Oct 30, 2011 7:56 pm | |
| - rkmdogs wrote:
It sounds like what you have is what was used on the "F"bodied cars,(Camaro & Firebird). This is a water-cooled system, not the air-cooled style used on the police car options. That's why I need to see pics of what you have. Thanks That is exactly what I have. It was used on more than just the F body. | |
| Subject: Re: oil cooler delete | |
