 Low Coolant Sensor for Light location on L05 350 OCC?
PostSubject: Low Coolant Sensor for Light location on L05 350 OCC?   Fri Oct 05, 2012 10:44 am
Anyone know where this sensor is under the hood? Twice yesterday sitting at a light, the light came on and I got the BONG BONG BONG BONG BONG BONG from the dash, and then it would go out. Checked the level in the radiotor and overflow and it's fine, not low. Think the sensor is sick.
PostSubject: Re: Low Coolant Sensor for Light location on L05 350 OCC?   Fri Oct 05, 2012 11:55 am
On the backside of the radiator down low on the rightside is the sensor!
PostSubject: Re: Low Coolant Sensor for Light location on L05 350 OCC?   Fri Oct 05, 2012 11:58 am
On the rad itself....yikes. Wonder if I can get it off without screwing up the radiator. Guess I need to pic one up before I flush the sucker out.
PostSubject: Re: Low Coolant Sensor for Light location on L05 350 OCC?   Fri Oct 05, 2012 1:18 pm
It'll come right out. I've taken mine out to clean it up and I've got a ton more miles on my rig.
PostSubject: Re: Low Coolant Sensor for Light location on L05 350 OCC?   Fri Oct 05, 2012 3:24 pm
You cleaned it? Did it fix it?
» Interview with Reginald Harrison, Royal Hamilton Light Infantry
» Canada and the Charge of the Light Brigade
» Dieppe Veteran Interviews, Royal Hamilton Light Infantry
» Saskatoon Light Infantry Lanyards
» 4th Light Anti- Aircraft Regiment RCA
