 Low coolant level sensor
Isurf
Isurf
Low coolant level sensor Empty
PostSubject: Low coolant level sensor   Low coolant level sensor Icon_minitimeMon Mar 14, 2022 9:46 am
My low coolant light came on yesterday. I stopped and checked, it does not appear to be low. Engine temp remains in normal range. I presume I have a sensor or connection problem. Haven't had time to look yet. I presume the sensor is in the coolant tank. Is there a simple test for a bad sensor, or do I just look for a replacement? I have and used my blue driver obd2 reader, it showed last night  coolant temp was stable  between 198 and 205.
Thanks,
PostSubject: Re: Low coolant level sensor   Low coolant level sensor Icon_minitimeMon Mar 14, 2022 11:30 am
That is a very common problem. But, there an easy fix and it doesn't cost anything.
Bang the side of the coolant tank with the side of your fist, several times. Problem should be fixed.
ayilar likes this post
Isurf
Isurf
PostSubject: Re: Low coolant level sensor   Low coolant level sensor Icon_minitimeMon Mar 14, 2022 4:36 pm
Thanks Tom
I'll give it a wack tonight
silverfox103 likes this post
Isurf
Isurf
PostSubject: Re: Low coolant level sensor   Low coolant level sensor Icon_minitimeTue Mar 15, 2022 9:50 am
Thanks again, all fixed!
silverfox103 and ayilar like this post
PostSubject: Re: Low coolant level sensor   Low coolant level sensor Icon_minitimeWed Mar 16, 2022 6:54 am
I was like that when I was a kid.
» 96 RMW coolant level sensor?!!
» TBI Coolant Level Sensor help
» Low coolant level sensor switch
» Oil level sensor p/n
» Oil Level Sensor
