| Smoked Lenses and Light Output | |
Bull
Posts : 164 Join date : 2013-02-09 Location : MA
| Subject: Smoked Lenses and Light Output Thu Aug 22, 2013 4:35 pm | |
| If this topic is better suited to another sub-forum, please move it at your discretion.
I want to upgrade the look of my car by adding a set of aftermarket headlights. I haven't committed to a set yet, but I know there are "smoked" options that seem to be popular.
My question for people who are or have run them is whether/how much they reduce the headlight output? This is definitely a concern. I plan to add one of those custom harnesses from Gary (?) with the relays to increase output since I absolutely cannot stand how pathetic my lights are and how much driving at night sucks because of it.
Thanks for any input. | |
YachtDriver
| Subject: Re: Smoked Lenses and Light Output Thu Aug 22, 2013 4:47 pm | |
| I ran them for a little while. I can say that the output is diminished. However the light pattern is better. I ran silverstars and it was back to ok. I changed to a clear set of lights and the light output is much better.
Gary's harness and silverstars is the best combo I have used so far. I am currently running his kit in my LAB daily driver with stock headlights and silverstars. The light output is ok. I may just switch to a set of clear lenses in the future. Not 100% sure what I want to do yet. I will say that after having the relay kit the light output is improved. I just cannot quantify how much it is actually improved by.
I may try the 9007 mod for even brighter output. Not 100% sure about this though. | |
Bull
| Subject: Re: Smoked Lenses and Light Output Thu Aug 22, 2013 5:08 pm | |
| I had thought, based on some things I read on the Impala board, that the headlight harness provided a "shah-zam!" type of improvement, but it sounds like your gains were more modest? | |
| Subject: Re: Smoked Lenses and Light Output Thu Aug 22, 2013 5:15 pm | |
| I plan on trying the 9007 mod sometime next week. Just need a day off to go to the yard and get some bulbs. Not going to shell out for new ones quite yet... |
benn
| Subject: Re: Smoked Lenses and Light Output Fri Aug 23, 2013 10:02 am | |
| i did the 9007 mod about two months ago. light output is soooo much better now, i cant believe the difference and my headlights could still use a better alignment. i would definitely recommend doing that mod, cheap, easy and makes a hell of a difference over the OEM bulbs for these cars. | |
Bull
| Subject: Re: Smoked Lenses and Light Output Fri Aug 23, 2013 10:14 am | |
| If I use the search function and type "9007" I get no results for threads or posts. Is there a how-to for this mod to show me what it is and how to do it? | |
benn
| Subject: Re: Smoked Lenses and Light Output Fri Aug 23, 2013 10:28 am | |
| Subject: Re: Smoked Lenses and Light Output Fri Aug 23, 2013 1:03 pm | |
| The clear housings, with casper shields, using high/low HIDs. Properly aimed. I've never been flashed, or pulled over, and have used HIDs for three years. I know there are plenty of HID haters, but if you are looking for better lighting, this is the way to go. | |
| Subject: Re: Smoked Lenses and Light Output Fri Aug 23, 2013 9:39 pm | |
| I run the smoked lenses with 6K HID's and have excellent light output and have never been flashed. 30 bucks for good HID's on eBay now! How can you go wrong?
I also ran those lights with Silverstars and an upgraded harness. Output was horrible. If you're not going to run HID's, DO NOT get the tinted lenses. | |
Ancient_1
Posts : 105 Join date : 2011-05-31 Age : 72 Location : Sun Prairie WI
| Subject: Re: Smoked Lenses and Light Output | |
