 LED headlight bulbs
LED headlight bulbs Empty
PostSubject: LED headlight bulbs   LED headlight bulbs Icon_minitimeThu Sep 25, 2014 10:07 pm
Anyone bought a set of LED high power bulbs yet?
Has anyone taken off a set of headlight lenses yet? and then re glued them? baking them in the oven?
PostSubject: Re: LED headlight bulbs   LED headlight bulbs Icon_minitimeThu Sep 25, 2014 10:22 pm
Not sure how they would work with a reflector design like we have. However, they are BRIGHT. There was an old garbage truck going the other way this morning, and it was sporting replacement round 7" headlights that were LED. I couldn't believe the output.
Shaneomac
Shaneomac
PostSubject: Re: LED headlight bulbs   LED headlight bulbs Icon_minitimeThu Sep 25, 2014 11:36 pm
I have not taken the caprice lenses off, although I have done a h.i.d. retro on my truck using some lexus rx330 projectors, i baked the lights in the oven at 250 for 10-15mins. To re-seal them I used rubber butyl and have not had any problems with moisture or anything of the sort going on 2 yrs in all weather types and plenty of high pressure washes.
PostSubject: Re: LED headlight bulbs   LED headlight bulbs Icon_minitimeFri Sep 26, 2014 8:57 am
I have a whisperjet harness and relays for the wagon,.
I was looking at 2005 lincolns, and 2005-7 dodge caravans,. and was wondering if i could mount a reflector into the b-body headlight,. get clear lenses etc,.
I would like to put projectors into the wifes fancy f**d, it is now relegated to daily driver and will be doing winter duty,.either hid's or led's,. or an LED light bar mounted to the roof,.Shocked
I scrapped the town and country van, it needed a new steering rack,. and everything was rotten underneath on the subframe,.
PostSubject: Re: LED headlight bulbs   LED headlight bulbs Icon_minitimeSat Sep 27, 2014 3:01 pm
Some of the aftermarket clear euro headlight for our cars have the casper shields, or reflectors. I had some on my wagon before doing the BMW lights. They worked pretty good with Gery's headlight harness, and 55w/100w bulbs. I used black RTV to reseal the clear lenses to the BMW buckets. I haven't had a hint of moisture behind the lenses as of yet.
PostSubject: Re: LED headlight bulbs   LED headlight bulbs Icon_minitimeSat Sep 27, 2014 7:38 pm
The ones I got have the casper shields. I really like them. I run hi/low HIDs in them.
LED headlight bulbs HPIM3743
LED headlight bulbs
» Found an automotive LED replacement bulb source 4/15/2015
» Aonther question about LED headlight "bulbs"
» LED/white corner lights
» how do you replace the license plate bulbs on the wagon tailgate?
» Looking for light bulbs for RMW door panels and map light
