 Charging problem
tailpipe
6 posters
tailpipe
tailpipe
Charging problem Empty
PostSubject: Charging problem   Charging problem Icon_minitimeMon Nov 23, 2015 6:35 pm
Ok I have a headache here...92 olds custom cruiser.. Charges fine when the temp is warm. after a cold night alt wont start charging... Sometimes if I whack the dash really hard on the left side it will come back to charging... I have already put a new alt on and a new battery also checked and replaced the gen fuse in the panel. Anyone ever had to deal with this and any possible fixes I have two parts cars to grab parts from....
Thanks
Paul
PostSubject: Re: Charging problem   Charging problem Icon_minitimeMon Nov 23, 2015 7:57 pm
Judging from the picture in your avitar, this has got to be Paul the second owner of the Ratmaster.
PostSubject: Re: Charging problem   Charging problem Icon_minitimeMon Nov 23, 2015 8:04 pm
Maybe its the needle in the gauge sticking when its cold,.
know where i could get a decent southern frame? Wink
PostSubject: Re: Charging problem   Charging problem Icon_minitimeWed Nov 25, 2015 9:22 am
Whacking the dash will only affect the gauge. Did you put a known good gauge on the system to see if the gauge is the issue. It could be a corroded contact on the cluster or gauge motor.
PostSubject: Re: Charging problem   Charging problem Icon_minitimeWed Nov 25, 2015 11:11 pm
As Fred and Nick said, the dash gauge may be physically stuck or a connection may be corroded. Put a multi-meter on the actual battery and measure the voltage with the engine running when the gauge is showing low voltage. If the battery is up around 13.5-14.5 VDC at idle with some load on it like headlights, heater fan and rear defrost, then the charging system is working just fine. If the battery voltage is low (~12v) with the engine running, then smacking the dash was just a happy coincidence, since the alternator output goes direct to the battery and not through the dash.
PostSubject: Re: Charging problem   Charging problem Icon_minitimeThu Nov 26, 2015 11:11 am
It might be another 4 years before he checks back in,. Wink
PostSubject: Re: Charging problem   Charging problem Icon_minitimeThu Nov 26, 2015 12:02 pm
Paul I got two known good occ gage clusters in my stash
PostSubject: Re: Charging problem   Charging problem Icon_minitimeThu Nov 26, 2015 7:50 pm
I have a good volt meter motor.
tailpipe
tailpipe
PostSubject: Re: Charging problem   Charging problem Icon_minitimeThu Dec 03, 2015 11:08 pm
Ok so an update... I put a new alternator on it just for shits and giggles I had one here.. started charging right away but the warning chime would still come on right after starting but everything else seems to be working fine.... Does it every time i start it... I also get the infil light coming on on the dash at the same time the chime comes on? So is my car just haunted?
Charging problem
» Charging AC question
» 93 Caprice Classic wagon, 5.7 and tow package, California car
» I think I may have a problem...
» one problem solved now new one PLEASE help
» Possible Diff Problem?
