 Front Brake upgrade
Danr63
Danr63
Front Brake upgrade Empty
PostSubject: Front Brake upgrade   Front Brake upgrade Icon_minitimeWed Mar 30, 2016 8:37 pm
just upgraded the brakes on both of our 96 roadmaster wagons. We used parts from a place called brake performance. http://brakeperformance.com/brake-rotors/?ad=google&gclid=CjwKEAjwtYSsBRCDx6rM1v_uqmsSJAAZgf2q_kir4DnvP7iLlBVEJ2cz5pdZliP6kHNtuplaDjTpHRoCrv3w_wcB Installed the slotted and dimpled one on ours and we love them! just one word to make you a bit wiser. With their kits they automatically send the large pads that are used with a hearse/police/ambulance application.(06140 part #) the pads most of our cars use are the same ones for a 92 roadmaster sedan ( 00520 part#) Once you get past that the brake work and stop great! If you get the large ones you will notice that you can't get the caliper back on even with it opened all the up. It misses by just a little bit (enough to make you think you did something wrong) just wanted to share. take care Dan
Deadmanonduty
PostSubject: Re: Front Brake upgrade   Front Brake upgrade Icon_minitimeWed Mar 30, 2016 10:31 pm
Or put the police brakes on! Smile
Front Brake upgrade
» Front disc rotating tight / front brake pistons doesn´t release
» Front brake pads
» Front Brake Rotors... what ones?
» Slight vibration after front brake job
» 96 Roadmaster front brake pads
